Yeah, that flowrate is a zero-restriction maximum rating, which you will never actually see in real life. Even worse, those TT pumps slow down really quickly under restriction, far more than even other common watercooling pumps.
To try and get a little perspective on this, when a guy named Martin over on Xtremesystems was doing radiator testing, he had his loop running at a measured 1.5gpm. And he was dumping about 600W into his system (probably 2.5-3 times as much heat as your processor is. Despite that, even in the worst scenarios, the water-in/water-out delta was only 1.5 degrees at most. Without getting too hung up on the exact numbers, but using that as a bit of a baseline, your loop likely has 1) a lower flowrate, and 2) hotter fluid. Now, your current loop is clearly working, but I'd suspect that adding more components (more restriction AND more heat), would likely hurt your current temps a fair bit.
That's my 2c, anyway.
__________________ i7 2600K | ASUS Maximus IV GENE-Z | GTX Titan | Corsair DDR3-2133 |
