Old March 22, 2009, 05:47 AM
magictorch's Avatar
Swiftech hydrx-not the nicest color but its: treated my blocks well, doesn't destroy motherboards after leaks, and survives sub zero temps in transit.
Old March 30, 2009, 10:17 AM
biff's Avatar
Distilled and ~5% glycol for me. I may go for some G11 or G12 (whichever it is) next time around just for a break from the green.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old March 30, 2009, 11:13 AM
gingerbee's Avatar
dis water feser fliud xp now trying out the feser black to see what it looks like ( have not seen any temp diff at all in any of the fluids i have used)
Old March 30, 2009, 11:30 AM
Dazmode's Avatar
Feser fluid with feser unti-corrosion and feser heat killer... as soon as I get them in. Distilled water + PTNuke for now.
Black feser looks black (very dark purple) in normal light, in UV it glows bluish. Seems results vary from tubing type... for UV part
Old March 30, 2009, 11:55 AM
element291's Avatar
Rootbeer and little chunks of candy cane for my loop.
I was first using distilled and hyrdx, now using feser one blue uv non-conductive fluid.
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
Not sure where to post this Phobia Peripherals 7 February 19, 2009 05:58 PM
Need help: NO POST miggs78 Troubleshooting 9 October 17, 2008 09:01 AM
No POST miggs78 Troubleshooting 8 August 21, 2008 06:40 PM
New Rig won't POST... qwerty Troubleshooting 17 November 24, 2007 01:20 PM
