<~----> Need something to test airflow (canned smoke?) - Hardware Canucks
Old June 11, 2007, 10:42 AM
Mibs's Avatar
Default Need something to test airflow (canned smoke?)
I was watching a clip on g4tv.com when i was looking around the net for info on air cooling. Here is a link to that clip. G4 - Feature - Yoshi's Mods: PC Case Airflow
So I noticed he used a can of smoke to demonstrate airflow and I thought that would be the perfect thing to help create the most efficient setup. So does anybody know where you can find these? Or even something that would serve the same purpose. I just got something from a friend and the local electric and plumbing store where you had to light it and hell did it generate alot of smoke but it was so uncontrolled that now my entire house is full of smoke. Anyone have any suggestions? I saw something on a couple websites that was used to test smoke detectors but I'm not sure if it would work or not.
Old June 11, 2007, 02:50 PM
Unklmo's Avatar
ciggie is the first thing that comes to mind, other than than, you can always try some of those incense cones. light one(or two) and place 'em inside your pc?
Old June 13, 2007, 10:10 AM
lcdguy's Avatar
don't use cigarette smoke since it will leave a residue and stink up your computer. I would try something like dry ice or a fog machine.
Old June 13, 2007, 06:50 PM
Here's an idea: make a suspended panel scale. It's easy: take a coat hanger wire frame, use string to attach and hang a playing card or piece of paper, and make a small ruler along the bottom.
Old June 14, 2007, 10:00 PM
Trial Member
Regin Smoke Pen #S220 only $44.95; Smoke Pen makes tracer smoke for air-flow and air-leak studies
Old June 15, 2007, 07:03 AM
grinder's Avatar
that looks awesome, i want one now _just because_. thx edgedamage
Lian Li PC-C32; Enough cooling/airflow? Nate_The_Great Cases 3 October 3, 2008 11:19 AM
Case Cooling and Airflow - How much does it matter CasheKicker Air Cooling 18 March 14, 2008 09:30 AM
Smell of Smoke + PC = Bad BALISTX Off Topic 7 June 7, 2007 11:28 PM
Check your airflow sir????? sswilson Troubleshooting 8 February 25, 2007 09:29 AM
