Old March 12, 2009, 07:27 PM
Supergrover's Avatar
Default Back to H2o
Well finally got everything reinstalled, leak test tommorow still have to sleave the tubes with carbonfiber sleaving. Be doing that tonight.
But for now heres a few shots, case is a Tt Armour modded, backplate hole and cable managment holes have been cut in and c-channeled. Painted the interior semigloss black 2 coats primer, 2 coats color 2 coats clearcoat.Top panel is cut for a 5.25 fan controller/temp unit and drilled for power and rest buttons.
Loop is a 655 with modkit, ek top, bitspower ultra watertank res, feser 1/2in uvblue tubing, OCZ hydroflo block. I had a mcw30 but the tubing angles werent right so, coils didnt help, so off it came.
rad is a PA120.2 with 2 yates and 2 evercool alum painted to match. Support is a bitspower rad support. Fittings are BP black sparkle 1/2in comp fittings.
R.I.P.
Old March 12, 2009, 08:01 PM
Soultribunal's Avatar
Wild setup Grover....
That is not only Clean but it looks solid and well thought out.
Good Pics!!! Is that the Armor Black Edition Case?
ST
www.realhardwarereviews.com
Last edited by Soultribunal; March 12, 2009 at 08:03 PM. Reason: Noticed something
Old March 12, 2009, 08:05 PM
ChuckleBrother's Avatar
Nice looking setup! I love when someone goes minimalist rather than putting 5 different colours of lightning:).
Thats a fantastic looking res too, should find out about one of those for my next tear down.
"...you play a mean banjo"
Old March 12, 2009, 08:17 PM
Thanks guys, the 2 wires showing in the bottom of the case are now hooked up, power/reset, and are hidden.
ST: Its a older Armour about 2 years old the interior paint job is new the ext stock. The top panel never got painted inside, since I cant see it from my chair IDC.
CB: 4 UV 12" CCFL's shed visable light and the damn PSU glows blue:( The 2 intakes are blue but dont spill much past the drive holders.
Old March 12, 2009, 08:31 PM
Babrbarossa's Avatar
Nice work dude
Old March 13, 2009, 05:36 AM
gingerbee's Avatar
you sir have just breathed new life into my armor lcs case i was talking about getting rid of it but after seeing this very nice i think this case may have to get painted thank and nice
Old March 13, 2009, 06:10 AM
Ahhh okay, so same vintage as my old one then as well.
It brought back a lot of memories, most good, some bad. But I will always hold a special place for the Armor Series of Cases.
Good Job all in all Grover, I really do like it.
Regards,
ST
Old March 13, 2009, 07:33 PM
Okay before I fill it and leaktest I need recomendations should I go with the sleaved tubes or naked tubes?
The tube were a PITA to use comperstion fittings on and IDK if I like the look.
Old March 13, 2009, 07:43 PM
3.0charlie's Avatar
What color are they?
Hydro-Quebec is salivating...
Old March 13, 2009, 08:40 PM
Keep the SLeeving Grover, that looks awsome.
Honest to god.
ANd I still love how you 'fitted' a Sentry 1 in the top of your Armor.
ST
LAN Party Eh is back! gnat Canadian LAN Parties & Events 21 March 18, 2017 04:22 PM
Welcome Back HWC Eagle Eye Off Topic 14 January 15, 2009 10:28 AM
Back up software?? Cowinacape O/S's, Drivers & General Software 7 December 31, 2008 06:00 PM
Back ordered my arz Krixxer Off Topic 0 December 19, 2007 11:51 PM
