Old March 11, 2009, 01:58 AM
This blocks even with the high price compares favorably with the gtz. Higher performance and better craftsmanship go a long way for blocks. Especially if the company release new mounts for the thing every once in a while.
My gtz initially leaked which really scared me because initially caused my display to go completely blue screen. Luckily after a good drying, everything works 4 months later. However to stop the gtz from leaking I had to put a ridiculous amount of pressure in the screws that hold the thing together. Enough that I began to strip the screws which is completely ridiculous.
Thats a nice block Zlojack. It looks really well made.
To quote semi quote Ali G.
" She look at the Heatkiller, very nice"
Old March 11, 2009, 10:20 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Seem to be nice blocks but they may have a tough time in an already saturated H20 market.. Prices seem about on par, if NCIX sold their stuff people may buy it.
Old March 11, 2009, 11:48 AM
MpG's Avatar
MpG MpG is offline
I'm coming pretty close to considering one these guys, actually. Some testing threads that I've seen, they seem pretty positive, and for whatever reason, my GTZ just doesn't seem to be giving 100%. And if you skip the shiny, these is a hell of a lot cheaper than Koolance's CPU-350 block.
Old March 11, 2009, 12:30 PM
Eldonko's Avatar
Gotta have the shinee!!
Old March 12, 2009, 09:20 AM
S_G's Avatar
S_G S_G is offline
Yeah, this is the block Langer is using in his build, I think, albeit a customized version. They're really nice, just no LGA771 mounting brackets. Then again, even if they had them I probably wouldn't want to spend twice the amount for blocks over Fuzions.
HTPC: MSI Z77A-G43 + i5-3570k@4.6 + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
max dc voltage in north america? Fr0sty Power Supplies 6 August 12, 2007 08:46 PM
Worst Comapanies in America 2007 Competition: Consumerist Babrbarossa Off Topic 4 March 20, 2007 02:07 PM
