Originally Posted by KaptCrunch hydrx is EG toxic make a trip to canadain tire an get prestone (in white bottle) pet safe anti-freeze PG is less toxic same as your girlfriend's eyeliner
OP use only 2 drop of PTnuke in loop. |
The only problem with this is , you have to knock the concentration down still.
Its 50/50 and running that through a W/C loop would lose out on some of the thermal properties.
The coolant that most Makers sell is Propolyne Glycol which is a G.R.A.S. rating (Generally Recognized As Safe).
Coolants with Ethylene Glycol , are not the best when it comes to WC loops, they have a high toxicity.
Gingerbee, if you were to use Water Wetter , make sure the rest of your coolant is Ethylene Glycol...as it doesn't mix well with Propolyne Glycol.
The best setup is two drops of Biocide (from either PT's or any Aquarium store) and something to prevent the issues with mixing metals in W/C loops.
Good Luck!
ST
