Hey guys, I did this really fast just to sort of show how I'd like to layout my loop. I just need to know if it will work logically. I'm thinking of taking off those two rear fans, mounting a dual fan rad with the fans attatched to blow the air through the rad, and out the back of the case.
The fittings would be at the bottom, the question is, would the pump be able pump the water up through the rad to cool it. Or will it just get pumped to the CPU Block, and half-a** bypass going all the way up through the rad?
*** take it easy on my drawing, i did it in about 2 minutes. Also, take it easy on me, im a total noob to WC***
Thanks
