Old March 4, 2009, 08:27 AM
matsta31's Avatar
What is that top ? and how tall does it makes the pump ?
Sold hardware again.....
Currently using WHS hardware....
Old March 4, 2009, 08:43 AM
ChuckleBrother's Avatar
Not mine so I'm not 100% sure, I THINK it's enaberif's, I found it as an example in the Watercooling gallery thread.
If I had to guess I'd say it's the XSPC restop(linky). As for the height: Dimensions: 73x62x96mm plus whatever the pump size is.
@OP: Another option you can take is this, same idea and quite attractive imo.
"...you play a mean banjo"
Old March 4, 2009, 08:49 AM
element291's Avatar
Hmm, I'll probably go with saving the money and just adjusting my current design.
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
Testing WC loop.. need help please miggs78 Water Cooling 11 September 14, 2008 10:28 PM
PA 120.1 loop position sswilson Water Cooling 27 September 11, 2008 03:34 PM
TJ-07 dual loop help.... turtletrax Water Cooling 17 August 13, 2008 04:56 PM
Fan loop SpateD Water Cooling 6 January 21, 2008 07:30 PM
My Soon-To-Be loop Kopi Water Cooling 5 October 23, 2007 12:49 PM
