Old March 2, 2009, 02:41 PM
donimo's Avatar
Default Pump is just too loud, can yo undervolt?
Will this damage the pump at all? I know its ok with fans, but what about pumps?
It is a DD CPX-pro, I have it on a foam pad with the rubber mounts, it hums above all the fans and vibrates the whole desk...
also the "3-pin connector" seems to be a waste of time, no RPM reading at all...
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old March 2, 2009, 02:58 PM
You need to find a way to stop the vibrations.
I have an old swiftech mcp350 pump and if it sits in my case it'll have a very annoying drone sound.
I had to take a piece of filter from my case and put a metal finger guard and put it on top of the foam then put my pump on that to stop case vibration.
Undervolting won't make a difference.
Old March 2, 2009, 03:05 PM
donimo's Avatar
argh, when I had it in my shop I couldn't hear a thing so I just drilled some holes and mounted it up, at home, NNNNNNNNNNNNNGNNGNGNGNGNGNGNN and big holes in my shiny case dammit.
I have it on a 1/8 inch foam pad, so I guess I need it to be more than that...
Old March 2, 2009, 03:08 PM
If you have only seen what I've tried to get rid of vibration oh man.
Old March 2, 2009, 03:10 PM
KaptCrunch's Avatar
sounds to me that the rotor/armuture is unbalanced causing vibes
Old March 2, 2009, 03:12 PM
Thin cases like my lian-li cause MAJOR resonance when the pump is on the floor.
These pumps NEED good insulation to quiet them down.
Old March 2, 2009, 03:20 PM
SugarJ's Avatar
I found that the tighter mine was mounted, the more vibration hum I got. It almost needs some slop so the rubber mounts can kill the vibration. I just got a piece of Petra's gel-stuff, I'm going to try that under the pump and just zap-strap it down.
Old March 2, 2009, 04:18 PM
donimo's Avatar
Ill try 2 layers of foam and looser nuts ( ) see if it makes a difference, if not maybe something more drastic.
its quiet, just makes everything it touches hum...
Old March 2, 2009, 05:20 PM
MpG's Avatar
MpG MpG is offline
Try to avoid actually bolting it, if possible. Often, just the tubing will hold it in place, with a few layers of foam underneath to make sure the case doesn't catch any of the vibes.
Old March 2, 2009, 08:46 PM
Jackquelegs's Avatar
I actually partially ziptied it with velcro foam. I never used the proper mounts for the CPX-pro
Iapetos
Zephyranthes
Sick of loud fans... chouchou Air Cooling 32 January 30, 2009 10:33 PM
loud pump kyle_L Water Cooling 19 January 26, 2009 06:24 AM
is the hdd supposed to be so loud? Bucklaz Storage 29 January 25, 2009 12:08 PM
How loud do raptors get? chouchou Storage 16 December 21, 2008 08:32 AM
Vendetta2 - Fan is loud? dadzilla Air Cooling 5 December 12, 2008 09:54 PM
