Old March 1, 2009, 09:14 PM
zlojack's Avatar
Default MM Horizon Exhaust Fans Question
I've decided to get the case I've wanted for the past year or so!
The MM U2 UFO Horizon
Do you think there will be a big difference going for a big window panel on top of the case vs. the original top panel which has two 120mm exhaust ports.
I'm going to have the duality front with six fans with 2 360 rads and three fans exhausting, two of which are on a 240 and the third on the rear of the mobo tray. Do you think the extra fans on top would help in getting hot air out of the case?
Here are the different panel options:
http://www.mountainmods.com/u2ufo-cy...own-p-438.html
Of course, the big window looks better, but I'm also concerned about getting the hot air out of the case.
What are your thoughts?
Old March 1, 2009, 09:35 PM
MpG's Avatar
MpG MpG is offline
Good choice! That's pretty much what I'm running right - Horizon w/ Duality front. I'd say your planned setup would probably benefit from having the two exhaust fans up top. The way the Horizon is setup, the two bottom fans aren't well suited to grabbing air, even if they don't have a rad restricting them. Furthermore, any air they do grab, is that much less air that ever reaches the motherboard. If you're going to watercool your chipset, it might not be such a big deal, but with all the power these i7 chips need, plus the NB, there's a pretty serious amount of heat being produced on the motherboard. Having only a single 120mm fan to remove it isn't ideal, imo.
Old March 2, 2009, 06:54 AM
magictorch's Avatar
I just bought that case 2nd hand. Its the standard configuration and both radiators are pulling the air in with the two top fans and one back fan exhausting. I tried with just the one at the back exhausting and it wasn't a good idea.
Old March 2, 2009, 07:38 AM
KaptCrunch's Avatar
the plexiglass will insulate case over the tin an attract dust
@ magictorch would be better to have flow reverse pullin at bark and blow out top
Old March 2, 2009, 08:34 AM
magictorch's Avatar
I'll give that a go tonight!
Old March 2, 2009, 10:13 AM
MpG's Avatar
MpG MpG is offline
It might be, but having eight fans on intake versus only three on exhaust has the potential to be unbalanced.
Question about Noctua NH U12P SE 1366 (Nickel plate, installing both fans issue) appplejack Air Cooling 5 January 13, 2009 01:44 PM
u2-ufo horizon air flow stormkiller22 Cases 0 March 28, 2008 03:19 PM
SagManQc MM UFO-HORIZON wc rig worklog SagManQc Case Mods, Worklog & Gallery 7 January 17, 2008 07:00 PM
Trouble On The Horizon mo' power Off Topic 0 August 22, 2007 06:51 PM
fan question 2x120mm rad 2 or 4 fans? Somed00d Water Cooling 4 July 30, 2007 11:08 PM
