-   -   ordered some more parts what else do I need (http://www.hardwarecanucks.com/forum/water-cooling/15311-ordered-some-more-parts-what-else-do-i-need.html)
Shadowmeph February 27, 2009 10:17 PM
Ok I order some more parts,Swiftech MCR220 , Swiftech MCB-120 Radbox ( just in case I can't figure out how to mount rad inside my case Primochill Primoflex Pro LRT UV Red 1/2IN ID 3/4IN OD Tubing (10ft) , Bitspower G1/4 Straight Compression Fittings for 1/2IN ID 3/4IN OD Tubing (Pair) x3. I already have the mcp655 and a custom v8 stinger cpu block with the 1/2 " fat boys , later I will be upgrading my vid card. what else do I need? I know that since there are 3 fittings on the stinger cpu heatsink that I am going to have to t it? or how do I do this ?
MpG February 27, 2009 11:02 PM
Yes, you're going to have to use a T-fitting. Make sure the center hole on the waterblock is the inlet, and the outside two are the outlet.
You might also want to go down to your local hardware/autoparts store and try to get a couple of thicker o-rings for the fittings going on the radiator, since the Swiftech models have a countersunk groove in them that might keep the standard compression fitting o-rings from sealing properly. Once you get the parts, try them and see - the pressure needs to be on the oring, no the fitting itself.
Shadowmeph February 28, 2009 10:09 AM
thats for reply. and thanks for the advice.
great ok now I just have to wait for the parts to arrive ...:bananafunky:
Edit I forgot to ask should I lap my CPU since I know that the stinger is totally flat?
MpG February 28, 2009 08:35 PM
Personally, I wouldn't bother lapping unless you think your temperatures are going to be the limiting factor. Depending on how high you overclock, and how much voltage you're willing to feed the chip, you might never reach the point where your temperatures are the issue. Furthermore, not all chips even need lapping in the first place.
Shadowmeph March 1, 2009 12:04 PM
ok I just thought that i might have to because the stinger was totally flat, this is a good thing because I am a little nervous in the lapping department. where do I find distilled water and how much do I need?
Supergrover March 1, 2009 12:18 PM
I just grab mine from safeway or somesuch, a 4 liter will last many loops. Think it was only a couple of dollers. IIRC
Shadowmeph March 3, 2009 02:39 PM
lol thats funny I never noticed it but probably walked right past it 1000 times lol
