Old February 22, 2009, 12:18 PM
MpG's Avatar
MpG MpG is offline
Now that's making me a little curious, because when I tried running a loop without the cap on (since that's normally just fine in a regular res), I got soaked. Thank goodness the loop was out of the computer. If you can do it, makes me think there might be an 'optimum' inlet and outlet, although I haven't actually seen it stated as such.
Old February 22, 2009, 01:09 PM
sswilson's Avatar
I'll probably take an extra day and swap the inlet/outlet around to see if it makes any difference. I only found one reference (through google) where the OP suggested that he had information from swiftech WRT an actual inlet/outlet on the QP-Res radiators. I had no luck when I posted the question on their website.
This is on my open bench so it's not that big of a deal for me to switch them around (aside from partially draining the loop).
http://www.hardwarecanucks.com/forum...html#post95015
Old February 22, 2009, 02:23 PM
donimo's Avatar
is it strange that my first w/c build was foam free the whole time? It had a few bubbles for maybe 5min or so, then nothing...
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old February 22, 2009, 02:34 PM
sswilson's Avatar
Nope, that's the way it should be, although some times it does take a while to get all of the microbubbles out. Most loops I've put together didn't take more than overnight to clear up completely.
Old February 22, 2009, 03:12 PM
KaptCrunch's Avatar
Originally Posted by sswilson
The "non-functioning res" is how swiftech themselves refer to what orientation will and will not work with the QP-Res rads.
I'm adding a discrete res to the loop, and am trying to avoid having to buy a non-res rad to replace the one I'm using.
I'm having problems with my loop not bleeding properly (it's been running for months and I've still got "foam" once it gets up to speed) and it's been suggested that having the barbs at the top of the rad will help it to bleed.
sounds to me that the new rad won't help you
Question are you using zipties for clamps ?
any chance of the said set-up pic's
Old February 22, 2009, 03:18 PM
sswilson's Avatar
I'm not concerned about a new rad "helping me"... I'm trying to ensure that flipping the rad over isn't going to blow up in my face... :)
As far as zip ties go... yep I am using zip ties, but I use 2 on each barb, and they're only on the barb portion (not creeping up on the hose).
I'll try to get a pic up in the morning.
Old February 22, 2009, 05:06 PM
3.0charlie's Avatar
Flipping it over will work, make sure the cap is tight and sealed. As for your foam issue, I found out from trial-and-error and using so many different pump/res combos that the smaller the res the more foam you get. If the res allows a clean flow to the pump - micro-bubble free, then you should not have any. Do you have clear tubing? Do you see the bubbles at the pump inlet/outlet, or from somewhere else in the loop?
Inlet/outlet made no difference in temps on many of my rigs.
Old February 22, 2009, 05:16 PM
sswilson's Avatar
I have a single piece of clear tubing (put it in specifically so that I could see the coolant :) ) that runs from the rad to the inlet of the pump.
  #19 (permalink)
Old February 22, 2009, 05:32 PM
3.0charlie's Avatar
So no way to know where the bubbles are created, or where turbulence could be an issue.
  #20 (permalink)
Old February 22, 2009, 05:33 PM
sswilson's Avatar
Other than the fact that it's coming directly from the rad, no.
installing OS Jim Guides & How-to's 6 January 29, 2009 12:52 PM
Best way of installing raid 1 Phobia Storage 3 January 8, 2009 10:55 PM
installing a motherboard Defiant CPU's and Motherboards 8 December 17, 2008 12:38 PM
help installing heatsink Zippoh Air Cooling 26 December 9, 2008 08:36 PM
Dell installing Linux! Babrbarossa O/S's, Drivers & General Software 0 March 29, 2007 11:52 AM
