Old February 19, 2009, 10:15 AM
Realityshift's Avatar
Default asetek lclc?
anyone have any experience with the asetek lclc liquid cooling systems at all? I noticed in the coolit pure review they had the cooling results in the testing but they never gave any specifics as to what they used to get those results (aka fan, size radiator ect.) id like to know how it stacks up against mid to high end air coolers.
Old February 19, 2009, 10:26 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
We use the LCLC in the Water Cooling reviews. It is in its stock form.
Old February 19, 2009, 12:53 PM
yeah but theres more then 1 stock form, theres the 120 and 240 versions and I could imagine quite a variance in cooling performance between the 2.
Old February 19, 2009, 01:02 PM
SKYMTL's Avatar
We purchsed this one:
NCIX.com - Buy Asetek LCLC PRE-FILLED Liquid Cooling System CPU Block Pump 120MM Radiator No Mounting Hardware - 35-101-1012103 In Canada.
However, I will make sure AkG includes the exact setup in his next review.
Old February 19, 2009, 06:18 PM
awesome thanks Sky, do you know how they liked using it as a setup? I noticed in that review it seemed to cool the OCed Q6600 pretty decently.
Old February 19, 2009, 07:58 PM
JD JD is offline
For $60, I think the CoolIT PURE is a better choice:
NCIX.com - Buy Coolit Systems [PURE] Lc Maintenance Free Pre Filled CPU Water Cooling Solution LGA775/AM2 - P1-1002/LCW1C In Canada.
Though IMO these single 120mm rad setups with some dinky pump really aren't that great and don't offer huge improvements over a good air setup.
You'd probably be happier with the results of that dual 120mm radiator Astek setup or one of Swiftech Kits (though those cost a lot more).
Old February 20, 2009, 06:15 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
I hate the LCLC's setup not really user-friendly and was a real PITA to install in comparison to Swiftech H20 setup and all the CoolIT's lineup. IF I was going to use one, it would be the 2 bay version as the Domino is a better single bay all in one unit...AND I would splurge for the LCLC's backplate accessory. I don't trust pushpin setups....YMMV etc etc :)
The LCLC does not come w/ a fan. For the Domino review I used the Domino's fan to keep it apples to apples....though I personally would drop a 120x38mm on it if I was using it in one of my systems 24/7. :)
"Like Lighting strikes, typically the shots you hear are the ones that didn't kill you. And as with lighting, take cover when you hear a miss...god might be finding range by walking his shots." - SM
"Pax Pro Eo Optimus Arma" - Unknown
"A society grows great when old men plant trees whose shade they know they shall never sit in." - Greek Proverb
www.nopperdogs.com
Old February 20, 2009, 07:02 AM
Soultribunal's Avatar
I think if you want to dip into the world of LC'ing without breaking the bank, or figuring out your own custom setup, the Pure or the Domino would be perfect.
They are very well thought out All in one Kits.
But, given the added features, I would say the Domino would be #1 choice.
Regards,
ST
The Below statement is True
The Above statement is False
Old February 21, 2009, 09:12 PM
Given the pure is often under $60 would you guys say it could handle a Q6600 overclocked to 3.4-3.6 for long term 24/7 use or should I just jump on some higher end air cooling? this is all depending on what the tax man brings me this month, if I get enough ill be going with the swiftech 240 apex kit. but if I have to aim lower Id like to know my options.
oh and if I was going with the asetek id for sure go with the backing plate parts, theres no way id splurge on WC just to lose some of the performance to lame push pins...
Old February 21, 2009, 11:36 PM
JD JD is offline
I think the PURE is more for running stock, not sure if it could cope with a OC'd 65nm Quad.
If you can't get the APEX, you could get the Swiftech H20-220 Compact.
The Astek stuff is more for OEM's than it is customers IMO. They don't exactly provide anything with them.
