  #21 (permalink)
Old February 19, 2009, 06:46 PM
3.0charlie's Avatar
1/2" tubing has a 3/4" wall, which takes a lot of space inside a case; and the temp difference between 3/8" and 1/2" is minimal. As for pumps, I mostly use aftermarket tops anyway.
Hydro-Quebec is salivating...
  #22 (permalink)
Old February 19, 2009, 06:49 PM
magictorch's Avatar
Ah I see, yes the thick walled tubing really takes up a lot of room.
  #23 (permalink)
Old February 20, 2009, 05:58 AM
Toronto122's Avatar
I don't think it really matters how much space I take up in a case that's the size of a small beer fridge...
I know I could have gone 3/8 all the way through, but I think that the TWO video cards (overclocked) will run the temp of the water up pretty good. So, that's why I went 1/2". And the cost difference is nominal.
What fans do you guys use on your computers? I'm thinking of getting some Scythe fans, but $20 each is a lot of money, especially when the case needs 7 of them!!!
Or, should I just put the really good, quiet ones on the rad, and put the fans I have (a bunch of misc fans) on the other holes and just drop the speed to nothing?
One more thing...my buddies and I were talking about hose clamps. I'm thinking of going with worm drive clamps from Canadian Tire...input?
ALSO...How much more cooling do you get from a 3 x 120 rad vs a 2 x 120? Is it substantial? Has anyone here ever done a dual rad system?
Thanks again...pics coming next week...
NZXT Rogue Cube Case
Intel i7 920 @ 3.8 w/Scythe Mugen 2
6 gb Patriot Viper 1600mhz low latency
Asus Rampage II GENE Motherboard
2 x Asus GTX 285 in SLI (710/1617/2700)
1 x 1tb WD Black
3 x WD 640AAKS in RAID 0
Enermax 85-1050 PSU
HP 30" 2560x1600, G19, G7, M-Audio Q40 Headset
  #24 (permalink)
Old February 20, 2009, 07:12 AM
sswilson's Avatar
I've been using 1350 RPM Yate Loons on all of my WC builds. Not the top performer, but pretty decent for the price.
  #25 (permalink)
Old February 20, 2009, 08:47 PM
Toronto122's Avatar
Well, it turns out a friend of mind is getting me a 3 x 120mm rad...what kind I'm not sure, I'll know more tomorrow.
Hopefully my stuff arrives by tuesday (day off)!!!
1 x 1tb WD Black
Enermax 85-1050 PSU
Pics of my watercooled HAF 932 :D ragenrok Case Mods, Worklog & Gallery 11 February 15, 2009 01:20 PM
my watercooled temp ebdoradz Water Cooling 17 December 20, 2008 03:08 PM
The Journey of a Watercooled GTX 260 Dadi_oh Water Cooling 22 October 30, 2008 03:59 PM
Ati 1900XTX goes watercooled Vinnie Water Cooling 11 February 12, 2008 08:10 PM
New Watercooled Setup cdn_Madrach Water Cooling 41 March 11, 2007 11:48 AM
