Old February 18, 2009, 04:10 AM
KaptCrunch's Avatar
looks if are 10mm (3/8') ID 13mm (1/2") OD tubing
Old February 18, 2009, 06:54 AM
Toronto122's Avatar
I think you're right about the size...I've ordered new barbs.
What do you guys think about watercooling the northbridge? Is this needed? IF so, what block would you use (keep in mind I'm not rich!! LOL)
Thanks
NZXT Rogue Cube Case
Intel i7 920 @ 3.8 w/Scythe Mugen 2
6 gb Patriot Viper 1600mhz low latency
Asus Rampage II GENE Motherboard
2 x Asus GTX 285 in SLI (710/1617/2700)
1 x 1tb WD Black
3 x WD 640AAKS in RAID 0
Enermax 85-1050 PSU
HP 30" 2560x1600, G19, G7, M-Audio Q40 Headset
Old February 18, 2009, 01:20 PM
MpG's Avatar
MpG MpG is offline
I wouldn't go the NB cooling route. The P6T's heatpipe setup pretty much require you to pull everything off, and replace them with full-cover waterblocks, which would easily set you back over $200. For that matter, I'm not positive there are even waterblocks for that board, since I believe there are some component differences between the standard and deluxe versions of your board.
For tubing, as Kapt. just said, you probably need 3/8"ID-1/2" OD tubing. That said, this is what's considered thin-walled tubing. I love Tygon myself, but the thinner-walled stuff really is half-assed for tighter bends. Other brands such as Primochill and Feser1 are slightly stiffer, but will be more kink resistant as a result.
Old February 18, 2009, 01:39 PM
Toronto122's Avatar
I ordered the Primochill stuff (black)... 1/2 internal diamater
thanks for the input on the northbridge...I'll leave it alone for now...
1 x 1tb WD Black
Enermax 85-1050 PSU
Old February 18, 2009, 02:13 PM
MpG's Avatar
MpG MpG is offline
Wait, what? 1/2" internal diameter? Those fittings on the back of your Koolance part need 3/8" internal diameter. The important part is that the outside diameter of the tubing also needs to be 1/2", otherwise the compression fittings won't go over the tubing properly.
Old February 18, 2009, 03:43 PM
Toronto122's Avatar
I'm replacing the barbs...! LOL
1 x 1tb WD Black
Enermax 85-1050 PSU
Old February 19, 2009, 05:31 AM
Toronto122's Avatar
So this is what I was thinking for my build...what do you guys think? Any input?
I know that T valves cause some turbulence in the lines, but I THINK that when all the micro bubbles are gone they shouldn't affect performance at all.
I was going to put one of these at the top, and one at the bottom...
That should make maintaining the system alot easier...
BUT, any other ideas are GREATLY appreciated!!!
1 x 1tb WD Black
Enermax 85-1050 PSU
Old February 19, 2009, 08:49 AM
3.0charlie's Avatar
It'll work, no worries; though there is already a fill port in the res. Slide out the unit if you need to fill the loop.
  #19 (permalink)
Old February 19, 2009, 04:59 PM
Toronto122's Avatar
I thought of that, but then you have to leave enough slack to get the res out...that's kinda ugly.
I'd rather just have the fill and drain. Place PC in tub, open bottom drain, open top fill...FLUSH...LOL
1 x 1tb WD Black
Enermax 85-1050 PSU
  #20 (permalink)
Old February 19, 2009, 05:34 PM
magictorch's Avatar
Why dont you like to use 1/2inch or 7/16th? Is it because youve got less options in terms of pumps? Just curious.
barbs, 3/8". I will never use 1/2" again.
I use the Danger Den Tieton FC block for my 260. Very efficient, 100% load and 47C.
Nice looking loop on the go there any way Toronto, I'd go with some nice bitspower compression and angled fittings. Just installed a 90 degree fitting from them (others on the way) and very impressed with its quality and performance, plus the other bitspower barbs used.
Pics of my watercooled HAF 932 :D ragenrok Case Mods, Worklog & Gallery 11 February 15, 2009 12:20 PM
my watercooled temp ebdoradz Water Cooling 17 December 20, 2008 02:08 PM
The Journey of a Watercooled GTX 260 Dadi_oh Water Cooling 22 October 30, 2008 03:59 PM
Ati 1900XTX goes watercooled Vinnie Water Cooling 11 February 12, 2008 07:10 PM
New Watercooled Setup cdn_Madrach Water Cooling 41 March 11, 2007 11:48 AM
