Old February 16, 2009, 09:51 AM
Default Complete Noob Needs Help
Hey guys, in a few days I'll be ordering my new rig which will contain:
GTX 280
E8400
750W Power Supply
Antec 300
The idea of this was to make a compact machine with the utmost future proofing. To further enhance this I wish to include some cheap WC. This is something completely unknown to me so I would like you to help me out by suggesting a setup that is versatile and compact for as cheap as possible for the CPU and in the future, GPU.
Thanks in advance!
Old February 16, 2009, 10:05 AM
3.0charlie's Avatar
A cheap wc loop is not worth it, since most systems are surpassed by high-end air rigs. If you wish to build a loop for the CPU and eventually the GPU, this is what you need. Be prepare to cough up ~400$.
Pump: Swiftech MCP-350 (or MCP-355)
Res: Swiftech Micro-res
CPU block: Swiftech Apogee GT, or GTZ.
GPU block: Danger Den Tieton full coverage block
Rad: Swiftech MCR-220
Fans: Scythe SFF-21F, 2x
Tubing: Primochill 10', 3/8" ID.
Liquid: Primochill, or Swiftech's Hydrx
Swiftech Radbox.
Metal barbs: 3/8", 10x.
Hydro-Quebec is salivating...
Old February 16, 2009, 11:00 AM
JD JD is offline
Yeah right, good luck keeping the costs down
Watercooling becomes a huge expense IMO, especially when you get to the point where you want to actually make it look really nice. Then you get into the $10+ Bitspower fittings and it's just downhill from there...
3.0charlie, wouldn't he be better off with a MCR320? I think a 220 is cutting it a bit close with a E8400 and GTX280. Also to add to your list, need all metal barbs IMO, and 3/8" for that matter if the OP wants to use 3/8"ID tubing.
Old February 16, 2009, 11:10 AM
3.0charlie's Avatar
Thanks for the barbs, forgot about those.
But for the rad, the MCR-220 can handle the E8400 and the 280. I had an i7 (oc'ed) and a 260 (oc'ed) on a MCR-220 which could handle the heat load no problem.
Old February 16, 2009, 12:13 PM
KaptCrunch's Avatar
for under $300 can get good starter kit
Swiftech H20-220 Compact CPU Water Cooling Kit DC its for $165 but no stock
Water Block Cooled GTX 280 & 260 Video Card
read all the manuals, don't be afraid to ask questions
note: don't use the supplied hydrx coolant use prestone pet safe anti-freeze in the white jug from any canadain tire store with distilled water, mix 10%
reason less toxic then the EG thats supplied with kit
Old February 16, 2009, 01:22 PM
JD JD is offline
That kit doesn't have the greatest CPU block nor is the pump overly great and well hard to replace if it dies.
Also that GTX block you linked, is only a passive heatsink for the memory and what not. You still need the Swiftech MCW60 block for the GPU itself.
People still use antifreeze? I though that was a thing of the past...
Most people run PT_Nuke + Distilled or Feser One Pre-Mixed Fluid (or other pre-mixed ones).
Old February 16, 2009, 01:37 PM
matsta31's Avatar
Pre mixed is not really worth it. PT nuke and the likes do the job at a lower cost.
Future proofing with an E8400 ?
I mean, future proofing in the computer world is bordeline impossible, but would it not be the time to go quad if you want to somewhat futureproof ?
Sure, the current crop of games and programs dont really use the potential of 4 threads, but I think (Hope) that in the next year or so, we will see more and more multi-threaded programs ?
Finally, the consensus is : dont go cheap water cooling, go high end air instead : OCZ Vendetta2, TRUE, sunbeam core contact with a nice fan will all do the job really well.
Sold hardware again.....
Currently using WHS hardware....
Old February 16, 2009, 01:47 PM
magictorch's Avatar
I agree with 3.0charlie,
Once you start to get into higher end blocks and fittings, water-cooling really pulls away "performance wise" from aircooling, plus with a bit planning a loop can be less intrusive or ugly than a huge air cooler-but I guess that depends on whos looking at it.
Fluid-wise although some may not like green, the hydrx is great stuff. Had a leak yesterday, due to a careless error. It was easy enough to clean off the board without wrecking it (was turned off though). Plus if you forget to drain the loop when posting your system long-distance in freezing weather the hydrx helps to prevent any burst pipes or leaks.
Swiftech Radbox.
Old February 16, 2009, 03:41 PM
KaptCrunch's Avatar
swiftech still uses alu on the full cover gpu so pt an others won't help
i use AF for my rads are outside an i use alu in loop
Old February 16, 2009, 04:05 PM
Chilly's Avatar
Only on the older stuff. In none of the newer stuff(even if it uses aluminum to cool the ram or w/e) does the water ever touch aluminum.
Build complete? Thanks for the help though. xile042 New Builds 2 December 11, 2008 10:12 PM
WTB a decent complete PC for my kids b1lk1 Buy/Sell & Trade 2 October 8, 2008 09:46 PM
complete noob at WC...need help... lukaszr Water Cooling 12 July 31, 2008 10:13 PM
Stage 1 complete. TwystedMonkey Off Topic 4 July 29, 2008 01:05 PM
Hello Kitty Laptop- now I am complete! Babrbarossa Press Releases & Tech News 10 June 8, 2007 12:59 PM
