-   -   quick question regarding loop routing (http://www.hardwarecanucks.com/forum/water-cooling/14862-quick-question-regarding-loop-routing.html)
donimo February 13, 2009 07:56 PM
hi all I have a 120 rad and a 240 rad, and am only running a chipset and cpu block for now.
My question is should I route it:
1) 240>cpu>120>chipset
or
2) 240>chipset>120>cpu
or
It seems on one hand that option 1 gives the cpu the coldest water cause its fresh from the 240, but then again the chipset doesnt put out much so the fluid in option 2 might actully be cooler than option 1, any thoughts?
brewer265@ February 13, 2009 09:58 PM
The easiest route is best for your loop. The temps will be barely different throughout the whole loop once it is up to temperature. Anybody who tells you different is full of bs.:thumb:
sswilson February 14, 2009 04:35 AM
Yep, yep......
Even without the extra rad, you wouldn't notice much difference in temps based on where you put the block.
Chilly February 14, 2009 05:11 AM
The simplest route, is the best route. Keep that rule of thumb in mind, whatever takes the least amount of tubing and distance will tend to be the best overall! :thumb:
donimo February 14, 2009 10:44 AM
sweet thanks guys!
so, the smartcoils I have are for 5/8 tubing :angry2:, are mild kinks that big a deal? not really kinks but you know...
brewer265@ February 14, 2009 10:45 AM
Can you show a pic? A mild kink could get worse later.
donimo February 14, 2009 10:56 AM
I am at a loss to avoiding a kink like that though, top hose has one too, just not as bad...
http://www.hardwarecanucks.com/forum...705a90bb84.jpg
http://www.hardwarecanucks.com/forum...705a91613a.jpg
brewer265@ February 14, 2009 10:58 AM
Just monitor it , it looks like it should be ok. If that is primochill it is pretty strong.
donimo February 14, 2009 11:10 AM
it is, funny how I have 3 diffrent brands of 1/2 barbs and they are all different sizes...:doh:
the bitspower ones on the cpu are waaay bigger than the swiftech ones.
thanks mang
nice ram eh?
brewer265@ February 14, 2009 11:12 AM
The bitspower where designed with the larger id to improve flow. And yes it is nice ram.:canadianwave:
