-   -   Internal rad installation? (http://www.hardwarecanucks.com/forum/water-cooling/14827-internal-rad-installation.html)
magictorch February 12, 2009 04:19 PM
Just wondering for an internal rad installation, do I need to use rubber washers, or anything like that, to prevent any shorting through contact with the rad and the case? Pretty sure you don't need to worry but just checking before I migrate my system to an MM horizon case.
cadaveca February 12, 2009 04:21 PM
Nope, no need, unless to prevent vibration from the fans tansfering to the case.
magictorch February 12, 2009 04:27 PM
Ok great, had to ask to be sure. I've got some nice antivibration pads with the bitspower 360 mesh grill v2..its not worth $20 though:sad:, plastic looks really cheap. Just gonna use the black mesh panels without the frame.
