Old February 10, 2009, 12:20 PM
Default another MRC120?
im putting together my loop but not sure if i need another rad or not.
i will be using eVGA780i mobo with CPU/d-tek v2 ,viperjohn/NB, MIPS/SB,D-TEK GFX V1,And i have a 350 with top and 1 mrc220 rad..
will i need the extra 120 or will the 220 be enough?
also have mcp655 but hoping the 350 with top will do.
what do you think?
thanks
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old February 10, 2009, 01:07 PM
donimo's Avatar
I have a 220 with an additional 120, but just the cpu/chipset.
I havent even fired it up at all, so my advice is actually usleless, thank you for your time, ah good day SIR!
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old February 10, 2009, 01:35 PM
3.0charlie's Avatar
What's your hardware?
Hydro-Quebec is salivating...
Old February 10, 2009, 02:44 PM
eVGA 780I/Q6600@3.6 G0/8800GTX 768MB
my wc HW
d-tek v2
mcp350 with top
viberjohn NB
Mips SB
D-tek GFX V1
Micro-res
MCR220
7/16" tubing
feserone coolant
yate loon fans
will the 350 be enough? even if add a 120
or will i need my 655?
thanks
Old February 10, 2009, 03:05 PM
Cptn Vortex's Avatar
pump should be fine, but I would say at least the 220 for the CPU. The single 120 should be ok for the GPU, but I think you are coming close to your thermal top for that loop. Its worth a shot anyway!
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old February 10, 2009, 03:06 PM
MpG's Avatar
MpG MpG is offline
Hit and miss between the topped 350 and the 655. I'd be inclined to stay with the topped 350, since it has a much lower heat dump, and really doesn't give up much performance in the flow ranges normally seen on watercooled systems. If you are, don't bother with the quad-insert on the Fuzion CPU block.
And if you can fit the 120 rad in there without too much trouble, I'd go for it. The extra restriction will be minimal, while it'll increase your radiator surface area by 50% - which might come in handy when you manage to load both your processor and video card at the same time.
Old February 10, 2009, 03:17 PM
ok guys,sounds like extra 120 it is,i have plenty of room,its going in my NZXT Tempest,huge case..
thanks for your input/info guys
Old February 10, 2009, 03:18 PM
3.0charlie's Avatar
Pump-wise, you should be fine. My loop has the 920, the NB and a FC 260 block, all using a 350 w/top and a PA120.2 - I used to have a MCR-220 in there, only for the CPU... Add the MCR-120? Definitely.
Old February 10, 2009, 03:40 PM
i ordered it
thought i maybe needed it but wasn't sure,now im sure ,,my loop just keeps getting bigger and its not built yet.lol
[WTB] Swiftech MCR120-QP Res Skyllz Buy/Sell & Trade 0 December 12, 2008 04:58 PM
2 x MCR120 vs Dual Rad enaberif Water Cooling 2 June 6, 2008 04:52 AM
