Old February 9, 2009, 10:02 AM
donimo's Avatar
Default different fans on each side of rad? (push pull)
Hey all, I was just wondering if it is ok to have different fans on each side of a rad? I have the sapce to fit 2 more fans on the back, and the filters on the front I put on restrict the flow quite a bit so it may make a difference.
Question have is that I have Noctua p12's on the front, but I have 2 spare antec tri-cools (no more p12's) and on low they are quiet so I was wondering if that is ok?
Cant find any infor to say one way or the other...
Noctuas are rated at 54cfm, tri-cools at low are rated at 39cfm, my line of thought was that the resistance from the filters plus the rad should slow that down quite a lot from the rated 54, so 39 from the tricools should help it out instead of slowing it down, thoughts?
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old February 9, 2009, 11:26 AM
MpG's Avatar
MpG MpG is offline
It should help things out. If the two fan speeds are different enough, the slower fan will be pretty much useless, but there has to be a pretty large difference in their speeds before that point is reached.
Old February 9, 2009, 11:35 AM
donimo's Avatar
I figured, the noctua on my 120 rad (no filter) is putting out a fair bit more air (by the hand-o-meter) compared to the amount coming out the 240 rad (with filters).
There is less than 30% difference between the 2 fans, and I think the filters+rad slows the air by at least 30%...
cool, the tricools are led fans to so much more baller...
How do you like my new rad? Push-Pull FTW!!! Sniper Water Cooling 26 December 8, 2008 08:09 AM
Fans for Push/Pull on PA120.2 Supergrover Water Cooling 20 September 14, 2008 07:18 PM
Push vs Pull on a Rad? Supergrover Water Cooling 10 October 16, 2007 07:13 PM
VR-Zone posts side-by-side comparison of 8800s and r600s Babrbarossa Video Cards 4 May 2, 2007 08:50 AM
DX10 / DX9 side-by-side screenies for CONAN Babrbarossa Reviews & Articles from the Web 4 May 1, 2007 04:00 AM
