Originally Posted by 3.0charlie No difference in performance. But having the barbs on the bottom of the rad makes bleeding a little more difficult. Make sure you move your case in all directions to clear the trapped air. |
I was thinking just the opposite.........
If your barbs are up top, you'd have to turn the case upside down to completely drain the coolant out of the rad. If they're on the bottom, the rad will completely drain so long as your drain point is below the rad.
