Old February 6, 2009, 12:34 PM
CTA's Avatar
CTA CTA is offline
Default UNI-SINK and GFX V2
i am planning to build second computer... not right now... i am still researching...
anyway... just curious... how good are they?
D-TEK Fuzion GFX V2 GPU Water Block
http://www.ncix.com/products/index.php?sku=31196&vpn=FZ%2DGFX2&manufacture=D%2D Tek%20Customs
D-TEK UNI-SINK Heatsink for GTX 280 & 260 Video Card,
http://www.ncix.com/products/index.php?sku=31197&vpn=U%2DSink%20Nv2XX&manufactu re=D%2DTek%20Customs
Old February 6, 2009, 12:50 PM
matsta31's Avatar
Got them for my 280.
The GPU block is really nice, good flow, good temperature.
I find the unisink better than any other solution you can use with a GPU only block. That said, it is not has efficient for the PCB has a Full cover block, it still does the job..... Some people prefer pointing a fan on it, but I dont find it necesseray. Altough, If I would be folding 24/7 whit the card, I would certainly use a fan with it.
Sold hardware again.....
Currently using WHS hardware....
Old February 18, 2009, 11:28 PM
CTA's Avatar
CTA CTA is offline
thank you for information... i also have last question... can i use it on gtx 285? i dont see any different layout from gtx 285 and gtx 280...
Old February 19, 2009, 06:05 AM
CanadaRox's Avatar
I'm pretty sure it wont work on a GTX 285 as there are more RAM ICs and the power area is a completely different layout. You can see the differences to the heatsink:
Project: Black and White
Old February 19, 2009, 10:42 AM
CTA's Avatar
CTA CTA is offline
ahh... thank you for pictures... i have a hard time to find that kinda picture to compare...
best air cooling heat sink to use for the E8400? Gameplaywarrior Air Cooling 27 December 8, 2008 10:33 AM
what is a decent air heat sink Shadowmeph Air Cooling 13 January 8, 2008 06:46 PM
Intel 775 Heat Sink - QUICK question mattydies Water Cooling 3 June 26, 2007 06:57 PM
Modifying my CPU Heat Sink??? mattydies Water Cooling 8 June 25, 2007 09:03 PM
Heat sink and fan selection for Intel Pentium D 915... mattydies CPU's and Motherboards 6 March 17, 2007 09:36 PM
