Old January 26, 2009, 09:51 AM
Phobia's Avatar
Default How powerful is the MCP655?
Got a quick question. Is the mcp655 good enough to handle a thermochill pa120.2, swiftech mcr220, fuzion cpu block, 8800gts full coverage block, and another full coverage block, or is that too much? The reason im asking, is im not sure if i should make a second loop or not. I don't want to if i can help it.. If i have to, i'd be using a 2nd mcp655 from my other pc.. so, it won't have WCing any more.
(whitty saying to be plagiarized at a later date)
Old January 26, 2009, 10:08 AM
Babrbarossa's Avatar
I am running HWBIGTX 360mm, mcr220, 2X full coverage blocks, apogee gtz and it does just fine. The flow calculator said it was fine too (can't find link)
psst, wanna see my binder?
Old January 26, 2009, 10:24 AM
I think it should be able to handle 2 loops. Phobes do you have the second rad for your chipset or what.. You mentioned, cpu and 2 video card with 2 radiators..
Old January 26, 2009, 10:57 AM
Phobia's Avatar
oh, no, i'd take the 2nd rad from my 2nd pc's loop :P So it would be down a pump and a rad.. sadly, all that would be left of that one is the cpu block :P
MCP655 Mod Kit Supergrover Water Cooling 45 May 7, 2009 06:41 AM
MCP655 power magictorch Water Cooling 16 October 11, 2008 08:47 AM
WTB: Swiftech MCP655 miggs78 Buy/Sell & Trade 0 October 7, 2008 02:39 PM
best setting ofr a MCP655 ebdoradz Water Cooling 15 August 19, 2008 05:50 PM
swiftech mcp655 wiring Corpus Masochist Water Cooling 15 September 9, 2007 09:30 PM
