Old January 26, 2009, 06:36 AM
matsta31's Avatar
Default Reservoir noise
Hi,
I am wondering if you guys are having noise problem with your reservoirs. I am using a Swiftech V2 and I can hear water sloshing sound from it. I tried filling it more but it did not change much.
This is my 7 or 8 loop I am building and actually the first with a reservoir. I have always been using T-Line but bleeding was starting to take to much time for me. But, there was absolutely no water movement sound.
Maybe a bigger reservoir could do the job with less sound ?
Sold hardware again.....
Currently using WHS hardware....
Old January 26, 2009, 06:49 AM
Varroa's Avatar
I have the same res and can't hear it above the case fans in my system (undervolted 1200 rpm fans running 900 rpm 120mm fans). When I am bleeding, working on the loop and have my case open and the res hanging outside the case I can JUST barely hear mine but it is no louder than the pump. Not sure how noisy yours is but if you can hear it inside your case it means one of two things. Either there is a problem or your case is SO quiet that the sound of the reservoir is the loudest thing in your case. What case are you running and how many fans (specs please)?
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old January 26, 2009, 07:37 AM
magelan's Avatar
My V2 res makes zero water noise and am a noise fanatic. Could it be there is some air bubbles in your loop somewhere such as inside the pump?
Old January 26, 2009, 08:31 AM
SugarJ's Avatar
How much fluid do you have in the res? Try topping it right up to the top.
I also find I have to rock my case to get all the air bubbles out of my rad, that makes a bunch of noise.
Old January 26, 2009, 08:58 AM
matsta31's Avatar
I'll try filling it to the top. By looking at it I think the water noise comes from the fact that water can move in it because it is just half full. Good point
For system spec :
I have a TJ07,
My top fans are :
ZALMAN FM3 and the stock Silverstone fan + two 92 MM stock silverstone on the side. All on a fan controller tuned down to low noise level.
In the bottom compartment, I have a PA120.3 +2 schythe 120 MM 1400 RPM + 2 YL 1350 RPM all on a fan controller and undervolted.
All in all they dont make too much noise.
Old January 26, 2009, 09:30 AM
CanadaRox's Avatar
You probably still have some small bubbles in your loop that are making the noise. I find when I first fill my loop its fairly loud, but once all the bubbles bleed out it becomes nice and quiet. Try tilting your computer around a bit and see if any bubbles come out.
Project: Black and White
Old January 26, 2009, 09:51 AM
MpG's Avatar
MpG MpG is offline
You shouldn't be getting any noise from that reservoir, as long as the fluid level is above the plastic deflector. In fact, you should hardly have any turbulence at all, above that deflector. I would guess that you've still got some air in your loop, or that the liquid level isn't high enough. It doesn't need to be right up the top, just above the deflector.
Old January 26, 2009, 10:20 AM
matsta31's Avatar
ok thanks,
it has ben running non stop for a week now, maybe there is some air left, but I tought a week would be enough. I'll try moving the case around a bit and make sure I always have water above the deflector. I'll see the result.
Old January 26, 2009, 10:39 AM
3.0charlie's Avatar
I've used the V1 version of the res quite a few times, and it was dead silent. I made sure the front top barb was the inlet, the the front bottom barb the outlet, and fill the res over the angled divider.
Hydro-Quebec is salivating...
Old January 26, 2009, 02:16 PM
That res should make NO noise.
As Charlie said top barb = In ; bottom barb = out
Res should NEVER be full and fluid should be just at the bottom of the plastic ramp.
If you are getting noise you possibly have air.
Is the res higher than the pump?
[WTB] Bay style reservoir! Sniper Buy/Sell & Trade 3 November 28, 2008 05:07 PM
XSPC Passive Aluminium Reservoir 150M Review cryostage Member Reviews 23 July 2, 2008 04:54 AM
In need of a *NICE* reservoir. lowfat Water Cooling 11 June 29, 2008 12:33 AM
WTB- WC'ing reservoir and possibly other stuffs Cardboard box with DSL Buy/Sell & Trade 5 March 26, 2008 05:25 PM
don't like the Swiftech micro reservoir Corpus Masochist Water Cooling 10 August 23, 2007 06:30 AM
