Old January 23, 2009, 08:13 PM
Default CPU + Chipset
Can a Swiftech MCR220 be able to sufficiently cool a chipset and cpu?
I'm thinking of going with a Swiftech MCW30 for my board.
I figure it will.. just wanna double check.
Old January 23, 2009, 08:20 PM
MpG's Avatar
MpG MpG is offline
Go nuts. I'm cooling my own X38 chipset and mosfets with an MCR120 and an S-flex running at about 600rpm, and one hour burn barely begins to warm up the rad exhaust air. Chipsets can hit high temps, but that doesn't necessarily mean they're putting out a lot of thermal energy. Besides which, iirc, the P45 chipset uses a smaller fab process, which will only make things easier.
Old January 23, 2009, 08:21 PM
Poifect.
I got this new DFI Jr matx board and without a fan on the NB it was hitting temps of over 50' haha but I was putting a bit of voltage through it.
Supergrover's Avatar
I am not real impressed with the performance of my mcw30 but it will fit just about any chipset, channels of some sort would have been nice.
I would say yes it should but have never used a mcr220, but my pa120.2 handle it NP.
Old January 23, 2009, 08:23 PM
Infiniti's Avatar
Pshh.. PA120.2 > MCR220.
Anyways, I had my E6750 in its own loop with the MCR220, and it kept it under 40 at 3.8.
Old January 23, 2009, 08:26 PM
No doubt but I have a ton of headroom so the mcr220 should handle it.
Old January 23, 2009, 09:13 PM
3.0charlie's Avatar
My MCR-220 cools both the 920 and the stock NB block of the X58-Extreme.
Hydro-Quebec is salivating...
Old January 23, 2009, 09:34 PM
Synth's Avatar
Using an MCR220 for CPU & Northbridge, and formerly an HD3870 when it was in my main rig without any problems.
Old January 23, 2009, 11:40 PM
SugarJ's Avatar
I use a Black Ice Stealth 240 to cool my CPU and GPU. The MCR220 is better, and I'd think it would handle that load no problem.
Old January 24, 2009, 12:13 AM
I guess you can say it is less restrictive, so would definitely do a better job. I was quite surprised to see the temps Gord is getting with his, especially running an E8400 and a hot 4870 card on a dual rad, so definitely would be able to handle that heat load.
Anyone want to school me on the 975 chipset? Nodscene CPU's and Motherboards 4 December 9, 2008 07:03 AM
e6600 using p35 chipset? Shadowmeph CPU's and Motherboards 7 January 7, 2008 11:53 AM
Chipset cooler for A8N SLI Cptn Vortex Water Cooling 4 December 10, 2007 02:34 PM
Choosing the best board/ chipset bmfmass Video Cards 3 November 21, 2007 08:32 PM
AMD 690 Chipset sswilson Press Releases & Tech News 4 March 2, 2007 12:54 PM
