Originally Posted by Lima Well then, I guess I' m gonna stick with the gear that I got and not go for three loops.
I have a couple of PA 120.3's, a couple of MCP 655's, a Fuzion ver1, EK NB block, DD FC Tieton and I just might get a EK mosfet block.
All one loop with one pump, or both pumps?
P.S
I haven't looked for a case because I was wanting to build one from the ground up but that might change. From your experiences/knowledge, which cases are well suited for modding? |
1. I have a single 655 handling a full single congested loop and running at around 35-38C load at speed 1.5 on the pump. One is enough at speed 3-5 for sure. The question you should ask is do you want to split the loop in two for better temps for the GPU and CPU separately?
2. The case you choose will greatly reduce the temps or increase the temps. If you have the budget (which seems to be the case), then Cooler Master Cosmos S or Cooler Master HAF932 seems to be the choice for a full tower. They're both aimed towards watercooling from the get-go. Cooler Master has just released a variant of the HAF 932 with air filters and less glitz (someone can point to the model). The HAF is priced at $150 whereas the Cosmos is closer to $250. There are otherwise good alternatives out there as well as if you feel like tinkering any case. Generally though, why bother if it's there?
