Old January 14, 2009, 10:11 AM
S_G's Avatar
S_G S_G is offline
Default How safe is this?
I am trying to use my FuZion v1 block on my LGA1366 rig. They still haven't released a plate for it. I didn't want to add any more waiting time, so instead of ordering a new block, this is what I've done:
I had some old 5.25" drive covers lying around. I rolled them up (too lazy to cut them) and slid them onto two of the screws for the block, and then added another pair of screws and nuts through the covers on the block itself.
The other two block screws are tightened onto the edges of the plate. They seem to give some pressure, but any sudden movement and it'd slip out of place. That's why I had to come up with something to make it a little sturdier. Got the basic idea from Linus' blog.
Think my ghetto mount will be sturdy enough? Will I even get enough pressure? I'm unable to test, since my RAM is still MIA (it was supposed to arrive today, dammit!).
It's all old! Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water (Goodbye, Skulltrail.)
Rocketfish LL case painted black // PCP&C Silencer 750W
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro (HD380Pro soon)
HTPC: E1200@3.2 + IP35 + 4GB DDR2-800 + HD4850 + Silverstone Kublai KL02
Router (WIP): Intel Atom 230 + Intel PRO/1000 GT + GS108T gigE switch + WRT54GL + a drawer
Old January 14, 2009, 11:01 AM
That entire setup screams danger to me.
The tubing.. the cpu hold down.
The res
The fans.
Old January 14, 2009, 11:13 AM
"Quote This..."
Just get some fender washers (small hole, large diameter) and do all 4 corners.
Old January 14, 2009, 11:17 AM
S_G's Avatar
S_G S_G is offline
Haha, don't worry about the res and fans. I'll be securing the pump with screws later today, and those fans are getting ziptied. I don't have the RAM yet, so I didn't want to secure them.
Fender washers, good idea. Gotta head out to Canadian Tire. Thanks.
Old January 14, 2009, 11:27 AM
Chilly's Avatar
The res
The fans.
I don't see whats wrong with the tubing, or the fans for that matter(ghetto "mounted" as they may be). that being said the rest of the set up doesn't look too safe.
Old January 14, 2009, 01:39 PM
S_G's Avatar
S_G S_G is offline
Hopefully it's sturdy enough to at least get the system going. I was just about to order an Enzotech Luna from NCIX, but then I noticed the Luna's LGA1366 bracket:
NCIX.com - Buy Enzotech TYPE-Z LGA1366 Retention Module for Luna CPU Block & Intel Core i7 CPU Socket - TYPE-Z 1366 In Canada.
It looks like it would actually fit the FuZion, so I'd save myself a ton of dough. Might be worth a shot, although I have a feeling the pressure may be a little lackluster.
Old January 14, 2009, 01:52 PM
Eagle Eye's Avatar
Funny I e-mailed them months ago and they said it would be soon, apparently not. I'll e-mail them again D-Tek needs to get off their ass on this one that e-mail I sent them was dated Nov. 11 its now the middle of January!!
Even for a C02 guy that H20 rig is looking a little dangerous, I'd hate to see or hear about anything going horribly wrong you have some pretty expensive parts there.
EE
Old January 14, 2009, 02:31 PM
hausner's Avatar
I bought this adapter and i dosent fit fusionv2
|::|CPU: i7 920 "D0"@?|::|MOBO: EVGA Classified|::|RAM: 6GB G.Skill Trident ddr3|::|GPU: BFG GTX 275|::|HDD: 2xSamsung F1 1TB|::|PSU: Ultra X3 1000W|::|Sound: Xonar DX|::|Powered by Heatkiller 3.0 LT/EK GTX275/EK Classified/Feser One X-360 TFC|::|Silverstone TJ 07
LCD: Samsung T260 25,5|::|Logitech Z5500
Project: Classified by Hausner - work in progress.
Old January 14, 2009, 02:45 PM
S_G's Avatar
S_G S_G is offline
Bah, thanks for the info haus. Guess it's time to get a new block. Any recommendations for i7?
Old January 15, 2009, 11:51 AM
S_G's Avatar
S_G S_G is offline
I guess it works, just need to avoid moving the case with too much force while it's on. Worst thing that could happen is it'll lose contact on one corner, but I'd still be getting fairly good pressure on two other corners, so temps shouldn't spike up to unsafe levels.
Either way, idle temps seem a bit high for water. Running it at stock right now. Does this seem too high for water to anyone else? It's the only thing on the loop, going to a 240mm rad.
e8400 safe OCs?? Malakei Overclocking, Tweaking and Benchmarking 16 February 5, 2009 02:29 PM
Safe to turn on johnnyuterus Troubleshooting 15 January 5, 2009 07:27 AM
Drive Safe Chilly Off Topic 1 December 25, 2008 07:56 AM
Safe to open? RCKage Power Supplies 4 November 22, 2008 07:44 PM
this safe ? Jim RAM 3 July 27, 2007 03:14 PM
