Old January 15, 2009, 01:19 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Just set up shutdown at a certain temp in your BIOS to be safe.
Old January 15, 2009, 01:29 PM
True enough, just to stay on the safe side... Oh and 35C on a i7 chip, you're already rolling, now it's screaming to be pushed.. Fulfil its wishes, overclock that thing, for the love of .... :P
Old January 15, 2009, 02:01 PM
S_G's Avatar
S_G S_G is offline
Really? Thought it was on the high side. Good to know, thanks a ton, guys. I'll set a shutdown temperature in a bit. Time to start OCing this bad boy.
HTPC: MSI Z77A-G43 + i5-3570k@4.6 + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
Old January 18, 2009, 08:57 AM
KaptCrunch's Avatar
turn you fusion 180 for outlet on the top and slide down them gear clamps abit more (have it on the smooth part)
e8400 safe OCs?? Malakei Overclocking, Tweaking and Benchmarking 16 February 5, 2009 03:29 PM
Safe to turn on johnnyuterus Troubleshooting 15 January 5, 2009 08:27 AM
Drive Safe Chilly Off Topic 1 December 25, 2008 08:56 AM
Safe to open? RCKage Power Supplies 4 November 22, 2008 08:44 PM
this safe ? Jim RAM 3 July 27, 2007 03:14 PM
