Old January 13, 2009, 11:10 AM
donimo's Avatar
Default 5/16ID, 7/16OD tubing useless?
I have 100ft of it is all.
I know I may be annoying with my recent WC questions, I just want to make a sort of "frankenstein" super cheap WC setup.
My wife vetoed the gas 2 stroke pump already, so now I am scrounging through the pile....
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old January 13, 2009, 02:15 PM
CanadaRox's Avatar
You could use that tubing on 3/8 barbs. It would be a tight fit, but it would work. Depending on what you have on your loop (how much heat load) you may want to step up to a larger size, but for an ultra cheap build, that tubing should be fine.
Project: Black and White
Old January 13, 2009, 03:49 PM
donimo's Avatar
so far I have a 120x1 and a 120x2 rad, a magicool cpu block and this tubing...
it would be going on the PC in the sig, CPU alone at first
Old January 13, 2009, 08:42 PM
CanadaRox's Avatar
For CPU only that size would definitely be sufficient. When (and if) you add your GPU, you may want to step it up to a larger size, though it is unlikely to have a huge impact unless your loop is saturated to its limit (and with 120*1 + 120*2, you wont be, even with your current GPU + NB + CPU, and even an upgrade to a quad in the future).
Old January 13, 2009, 09:36 PM
donimo's Avatar
well thats reassuring, is there anything about the tubing that is sold as "pc wc tubing" that is special? this stuff is PVC I think, have to check again...
Pretty thin (1/8") but I doubt its gonna burst or anything...
Old January 14, 2009, 01:20 PM
biff's Avatar
The stuff sold as specialty WC tubing is less prone to kinking (plus softer and nicer to work with) over the standard vinyl home depot stuff.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Cutting tubing elninio Water Cooling 11 June 10, 2008 04:14 PM
Fans for WC and tubing Dashock Water Cooling 7 May 5, 2008 10:13 AM
Useless Thread loath Off Topic 1 January 20, 2008 07:02 AM
Tygon tubing Dark Water Cooling 5 December 28, 2007 08:42 AM
would use a upgrade vista. make my xp cd useless dirtfarmer O/S's, Drivers & General Software 2 November 21, 2007 01:27 AM
