Old May 23, 2007, 10:58 AM
Babrbarossa's Avatar
Default New watercooling products at NCIX
There's some interesting WC products coming into NCIX now- I'd like to compare the accelerator nozzle for the Fuzion waterblock to stock.
Ek Water Blocks Full Coverage NVIDIA GeForce 8800 GTS GPU Block with Mounting Hardware G1/4 Threads
Water Accelerator Nozzle Kit for D-TEK Fuzion CPU Block
Danger Den MAZE5 GPU Water Block for Most NVIDIA & ATI Video Cards 1/2IN Barbs & Zalman RAM Sinks
Magicool 360 UV Blue Triple 120MM Water Cooling Radiator G1/4 Threads (comes in single 120mm too)
Look here for more
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Old May 23, 2007, 04:43 PM
Misoprostol
Guest
Posts: n/a
expect to see a FuZion w/ accelerator nozzle added to my CPU block charts.
Old May 23, 2007, 07:26 PM
Excellent Smithers...
Old June 3, 2007, 12:39 PM
lowfat's Avatar
This is the only place I have ever seen the Nozzles listed. They aren't even on the D-TEK site yet. It says 1-2 week special order, but I doubt you'd get them in that time.
1. Xeon ES 4c/8t * X79-UD3 * HD7970 * 16GB DDR3 * 64GB Crucial M4 * 80GB ioXtreme * 1000W Silverstone
2: 27" iMac * i5 750 * 80GB X25-M G2 * 4GB DDR3 *
3: 2600k * P8P67 Pro * GTX460 * 16GB DDR3 * 40GB X25-V * RR2314 * (2) Sans Digital TR8M-B * 46TB * 1050W Enermax
Old June 3, 2007, 01:55 PM
Patriote's Avatar
ANybody have a pic of that Nozzles thing ? What is it ?
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz (for now)
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old June 3, 2007, 02:03 PM
AFAIK It's meant to increase the force with which the water makes contact with the heated surface inside the block to increase the heat transfer. Here's a kit for Danger Den, so I assume it will look like one of these parts.
Old June 3, 2007, 02:20 PM
Patriote's Avatar
I see. Im kinda a bit disappointed about my FuZion. It doesn't hold temps that good. And i mounted it the tightest i could while not making the board to bend. I think im going back to my Apogee or maybe ill get an Apogee GTX. My apogee gave me freaking good temps on all processors i tested it. Even the Storm s*cked more than my lovely Apogee.
Anyway, thanks Babr!
• - Noctua NH-D14
Old June 16, 2007, 10:24 AM
lowfat's Avatar
A Fuzion should be walking over an Apogee. Try completely remounting it. And a Storm really isnt that good of a block for LGA775 CPUs.
Old June 16, 2007, 11:47 AM
3.0charlie's Avatar
It's meant to vary the water flow, by increasing the opening (thus reducing the flow) or decreasing the opening (increasing the flow). If you have a variable speed water pump like the MCP-655, you don't need nozzles.
What I don't like is the fact that any component added to a loop will create more turbulence and possibly decrease the water flow, without even knowing about it. Also, adding a smaller nozzle may just create a back pressure - and you don't want that.
I've played with different setups about one year ago, and only higher temps (by 1-2C, that is) were measured. I wasn't convinced of the added benefits of nozzles.
My 0.02$, CAN of course.
John
Old June 16, 2007, 04:04 PM
Patriote's Avatar
Yeah problem is fixed by now. The motherboard is just reading temps pretty wrong... Coretemp reads temps correctly. I think...
• - Noctua NH-D14
Where to buy water cooling products in Toronto? Jack Rabbit Off Topic 1 September 9, 2007 11:23 AM
New products at NCIX Babrbarossa Computer & Electronics Hot Deals 1 April 17, 2007 08:52 PM
Some interesting products coming to NCIX Babrbarossa Computer & Electronics Hot Deals 1 April 2, 2007 11:52 PM
Legit Review Has Sneak Peak - Ultra Products 2000W ATX Power Supply Supergrover Reviews & Articles from the Web 0 January 3, 2007 08:34 PM
HardwareZone list the best products of 2006 Supergrover Press Releases & Tech News 0 December 27, 2006 04:12 PM
