Old June 17, 2007, 05:07 PM
Babrbarossa's Avatar
It's meant to vary the water flow, by increasing the opening (thus reducing the flow) or decreasing the opening (increasing the flow). If you have a variable speed water pump like the MCP-655, you don't need nozzles.
What I don't like is the fact that any component added to a loop will create more turbulence and possibly decrease the water flow, without even knowing about it. Also, adding a smaller nozzle may just create a back pressure - and you don't want that.
I've played with different setups about one year ago, and only higher temps (by 1-2C, that is) were measured. I wasn't convinced of the added benefits of nozzles.
My 0.02$, CAN of course.
John
I don't think that their purpose is to increase or decrease flow rate per se- the change in flow rate is a side-effect of their actual purpose, which is to create a 'spraying' action so that the water contacts the inner surface of the heatsink with more force- this comes at the cost of flow rate if using a restrictive nozzle, and it seems that some have found that if you're using a strong enough pump, that the trade-off is worth it.
Old June 21, 2007, 11:48 AM
Misoprostol
Guest
Posts: n/a
Babs is dead on with this one. The nozzles are to create an impingement effect, which accelerates the water that is hitting the pins inside the block. This should yield a 1-2C difference in performance.
Where to buy water cooling products in Toronto? Jack Rabbit Off Topic 1 September 9, 2007 10:23 AM
Legit Review Has Sneak Peak - Ultra Products 2000W ATX Power Supply Supergrover Reviews & Articles from the Web 0 January 3, 2007 08:34 PM
HardwareZone list the best products of 2006 Supergrover Press Releases & Tech News 0 December 27, 2006 04:12 PM
