Old January 7, 2009, 09:04 AM
kyle_L's Avatar
Default film in tubes
when i put my new rad in last night i had to cut some new tubes and i noticed a film on the inside of the old tubes. can anyone tell me what it is and if its bad. I'm using feser one cooling fluid UV pink.
Gotta Love Timmies Coffee.
Old January 7, 2009, 09:13 AM
Sniper's Avatar
Are you using anything to prevent Algae? If not get some PT-Nuke & add only what is recommended as per instructions. more will hurt your system rather than help it.
Old January 7, 2009, 09:19 AM
kyle_L's Avatar
is there anything household that i could use, I'm outa money
Old January 7, 2009, 09:37 AM
Sniper's Avatar
hmm there was something mentioned I just have to find it again. I'll be back with an answer if someone doesn't beat me to it lol.
Old January 7, 2009, 09:58 AM
Sniper's Avatar
If you have any fish tanks or know someone who does they might have a bottle of Aquarium Algaecide prolly only need 1 drop in your loop. Other than that i'm still looking lol.
Old January 7, 2009, 11:30 AM
Its from the coolant as a lot of them do stuff like this.
Don't add anything to it because it should have a biocide already.
This is why distilled water + pt nuke is the best solution.
Old January 7, 2009, 12:01 PM
MpG's Avatar
MpG MpG is offline
What kind of tubing? Tygon usually goes cloudy in a month or so, even if you only use straight distilled water.
What kind of radiator? Some radiators (Thermochills, for example) need to be heavily flushed out before using, or they coat your loop with flux leftovers.
Old January 7, 2009, 02:39 PM
kyle_L's Avatar
its not from the rad cause the tubing had the film before the rad was installed. and the tubing is made by clear flex and the rad is a swiftech mcr 320
Old January 7, 2009, 03:58 PM
Chilly's Avatar
Don't worry about it. Its been a mystery to water coolers for years, eventually all tubes cloud. There are ways to delay it, and reduce it, but eventually all tubing will cloud, even in pure distilled water(though it seems stay "clean" the longest).
Old January 7, 2009, 04:13 PM
MpG's Avatar
MpG MpG is offline
For what it's worth, I find that the loops I run Swiftech's Hydrx stuff in seem to stay clearer much longer. Of course, you're stuck with green then. Might be something about a little Glycol that does it? Not entirely sure.
Joaquin Phoenix says will quit film for music BALISTX Off Topic 2 October 30, 2008 08:37 AM
Vinyl Film rsnt Off Topic 4 July 2, 2007 08:54 AM
