-   -   Watercooling Shopping Help!! (http://www.hardwarecanucks.com/forum/water-cooling/13561-watercooling-shopping-help.html)
Soultribunal January 6, 2009 08:42 AM
Hey Everyone,
Well I've started looking around and pricing out my components.
However, i've run into a small snag.
I cannot seem to find the Swiftech MCR120 Rad without the Integrated Res.
The one with I believe will be to tight to fit into my application, so I'm at a loss as to what to do.
Any Alternates (companies) you guys can suggest for me?
Or perhaps you might know better than me where to find that rad?
I don't want to revert back to anything TT if I don't have to.
Thanks!!!
ST
Shadowmeph January 6, 2009 10:45 AM
Hmm it took me athree clicks to find one at NCIX ;) NCIX.com - Buy Swiftech MCR120 Quiet Power Single 120MM Water Cooling Radiator Black G1/4 Threaded - MCR120-QP-K In Canada.
enaberif January 6, 2009 10:48 AM
Originally Posted by Shadowmeph (Post 135190)
Being a smart ass at times is a bad thing.
They don't have any in stock.
You may have to order from somewhere like Performance PCs.
SugarJ January 6, 2009 10:55 AM
No stock at Petra's either. They do have a Black Ice Stealth 120 in stock though.
Shadowmeph January 6, 2009 10:58 AM
I apologize if that is the way that I seemed to have come across. I thought that the wink at the end of my sentence would have been a sign of trying to help and not intended as what you call a "Smart Ass"
Soultribunal January 6, 2009 11:51 AM
Well, I didn't take it as a smart ass remark, but I appriciate you sticking up for that Ena.
Feser 1 has them in stock at NCIX , but I wanted to stick with the advice that everyone had given me here.
I'll start digging US sites I suppose and see what I come up with.
Running into a similar problem with the GTZ waterblock, but I have a few Alternates for that.
Unlike everyone else here, I don't know all the places to look for WC gear, because as stated before, I have only ever purchased Ready to Use Kits (I.E Bigwater / Silent Water). So, putting this together is sometimes confusing, and frustrating.
If anyone knows any sites, please let me know.
Thanks for all the great help.
ST
Linus January 6, 2009 12:35 PM
If you want a single 120mm rad we have them coming within a couple weeks from Swiftech. Unfortunately the Feser One radiator is the only other one that we are able to stock regularly at this point :(
As for CPU blocks, our XSPC blocks DO includes 1366 mounting hardware even though it's not listed in the product description yet.
Regards,
Linus
NCIX.com Product Manager
SugarJ January 6, 2009 12:38 PM
Exmortis has a Swiftech 120 rad in his FS thread.
http://www.hardwarecanucks.com/forum...ing-parts.html
Soultribunal January 6, 2009 01:34 PM
Woot, Thanks SugarJ, that might just be what I need.
Linus, Yeah it happens. Places go out of stock all the time, you won't see me having a fit about it. I Won't need a LGA1366 Setup just yet, this will be for old LGA775. However it is good to know in advance for future Compatibility with these things.
If all else fails, I'll either wait for stock, or Find other Rads to use.
Damn my constraints for Internal Setups, but stubborn is in my genes lol.
Thanks Everyone,
ST
Linus January 6, 2009 01:55 PM
Now that I think of it, I might have a 120mm rad or two kicking around.... If Exmortis can't deliver for whatever reason, let me know and maybe I can hook you up.
If all you need is LGA775, I can probably give you a great deal on the single XSPC Delta X20 block that doesn't have LGA1366 hardware (I have it tucked away). PM for details. It's supposed to be a very good block.
