Old January 4, 2009, 06:08 PM
JD JD is offline
Default Will these fit?
Coolingworks Black Mini Coolshroud for 120mm Radiators
Even though Swiftech isn't listed, do you think it would be possible to use 2 of them on my MCR220?
Old January 4, 2009, 06:20 PM
Iamcanadian7's Avatar
No, it won't, I'm pretty sure Thermochill and HWL's spacing is different than Swiftech's.
Someone correct me if I'm wrong though.
Old January 4, 2009, 06:22 PM
JD JD is offline
Yeah I know that much but perhaps I could do some minor modding to make it work?
Old January 4, 2009, 06:30 PM
MpG's Avatar
MpG MpG is offline
Within each fan, the hole spacing for any 120mm fan is standardized, it's the distance between multiple fans that's the issue. So those shrouds should work for any single 120mm rad.
The problem that I'm seeing is that you're thinking of putting them on a dual radiator. These days, HWL and Swiftech are both using 15mm fan hole spacing, which basically puts the fan frames right flush against each other. But by the same token, anything that covers more area than the actual fan (which those shrouds appear to do) is going to have trouble being placed right next to another of the same, since they'll be trying to overlap each other. To make these shrouds work, you may have either bend the plastic a little to force them to go side-by-side, or trim a few millimetres off of one/both of them.
Old January 4, 2009, 06:36 PM
JD JD is offline
Hrm sounds feasible. And we're talking like <5mm right?
For $3 a piece no harm in trying IMO. I've wasted more money on other things that haven't worked out as planned.
Old January 4, 2009, 06:46 PM
MpG's Avatar
MpG MpG is offline
1-2 millimetres I'm guessing. Hard to say for sure from the pictures. I had the same problem on a dual Swiftech trying to put THESE filters on. It wasn't by much, but they just slightly overlapped. I just held one of the filter edges up to the belt sander for 10 seconds and the problem went away.
In your case though, the fact that they're shrouds means that taking any of the edge off might ruins the airtightness. If you're serious about shrouding, maybe try to evenly take a little off both, so they meet each other evenly? Then a thin line of silicone/glue would seal the gap to maintain airtightness. Yeah, you can only go so wrong for $3/each.
Old January 4, 2009, 07:27 PM
JD JD is offline
Well I don't have a belt sander but I think I could still figure something out (aka manual sanding) if its only a couple millimeters.
Old January 4, 2009, 11:38 PM
^^ Maybe sanding with a dremel, if you do.. :)
Guess sanding should fix any issues you encounter. As MpG said, it is hard to say from the picture.
Old January 5, 2009, 08:23 AM
JD JD is offline
Don't have a dremel either
Good ol' fashioned hand tools
