Old January 4, 2009, 03:04 PM
SugarJ's Avatar
Default M4 screws
Anyone know where I can find M4 diameter screws? That's the only size that will fit in my Black Ice rad, and I need to find some more so I can go push/pull.
The 4 stands for 4mm apparently.
Old January 4, 2009, 03:33 PM
Iamcanadian7's Avatar
Yea it stands for 4mm, they didn't carry them at Rona or Home Depot so I had to go to a store that specalized in fasteners. The one I went to was called Fasten-all. If you look in the yellowpages under screws or fasteners I'm sure you'll be able to find a store that carries them.
Old January 4, 2009, 04:35 PM
Sniper's Avatar
I've always had luck finding odd stuff like that at Kent to so might want to check there also?
Old January 4, 2009, 05:01 PM
SugarJ's Avatar
Just google'd Fastenal, there's a store 5 minutes from my work. I'll check it out tomorrow.
Thanks.
Old January 5, 2009, 10:17 PM
SugarJ's Avatar
FYI, Fastenal has these M4 screws to fit Black Ice rads. My local store has to bring them in from their distribution, and I have to buy a minimum of $10 worth, and I have to wait until Friday. Still cheaper than buying a new rad.
Old January 6, 2009, 10:17 AM
You know Sugar, sorry for being late, I should have mentioned earlier.
Well, I have the same rad as you do, and I use regular 8-32 1 1/4" screws really, I find the 8s to be more tightening and secure than the 6s. I have 2 GT Stealth 240 rads and both are using 8-32s.
Old December 3, 2011, 07:04 PM
Thanks for the info, guys!
I need a few of these to roof-mount my projector. Turns out there are two Fastenals in Saskatoon and I'm heading there tomorrow. *Fingers crossed that they'll have them in stock*
Old December 3, 2011, 07:35 PM
ZZLEE's Avatar
Thread from out of blue
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old December 3, 2011, 08:19 PM
chrisk's Avatar
Folding Captain
I buy M4 screws for my Black Ice from Canadian Tire if a Fasenal is not convenient.
Fold for team #54196
Old December 3, 2011, 09:16 PM
Soultribunal's Avatar
Most Partsources too will have an isle for these. I have all kinds of M4's at my Part Time gig. As well, Bolts Plus stores if they exist out that way should have it.
-ST
[WTB] CATHODES (UV AND NON), WD HDD's, THUMB SCREWS! Cadence Buy/Sell & Trade 1 November 21, 2008 06:49 PM
WTB: D-tek Fuzion Pro-mount or just mounting screws Jackquelegs Buy/Sell & Trade 6 October 29, 2008 07:23 PM
Thumb Screws WolfBane Off Topic 2 August 4, 2008 05:32 AM
Lian Li HDD Screws miggs78 Cases 12 June 22, 2008 01:03 PM
Revenue Canada Screws up Electronic Tax Filings Babrbarossa Off Topic 8 March 9, 2007 09:22 AM
