Old January 2, 2009, 12:04 PM
SugarJ's Avatar
Default Cosmos S or Black Pearl
So, I had a small windfall yesterday. Came home with an extra $300. So now I can afford to buy a new case. I intend to do an internal mount build using the parts in my sig.
So help me decide, Cosmos S or Black Pearl? Same price.
NCIX.com - Buy Coolermaster Cosmos S Black E-ATX Aluminum Case 7X5.25 4X3.5INT Front USB & Sound - RC-1100-KKN1 In Canada.
NCIX.com - Buy Tagan Black Pearl Full Tower E-ATX Case Black 7X5.25 8X3.5INT No PS Side Window - BLACKPEARL/10070 In Canada.
Thanks.
Old January 2, 2009, 12:06 PM
sswilson's Avatar
The black pearl is a beautiful case, but would require some modding to do an internal install.
How much work did you want to do?
Old January 2, 2009, 12:10 PM
Black Pearl isn't worth it to much work to do anything with it.
Old January 2, 2009, 12:26 PM
SugarJ's Avatar
I could go mesh fronts on the drive bays, mount a 240mm rad there like I did with my 900, mount to the top blow holes with minor work, or remove HD cage or 2 and mount on the bottom.
Of course, there would be minimal work on the Cosmos, and the only thing I don't like about it (mesh window) could fixed with an order off Newegg for $34.
What I'd really like is to be able to afford a Murdermod TJ07 case, but that ain't happening soon.
Old January 2, 2009, 12:57 PM
But modding it makes it worth every penny!!..
Sugar those are 2 very nice cases you picked man.. Well if you really see, modding the black little bit, you can get at least 2 radiators mounted inside easily.. http://www.hardwarecanucks.com/forum...pearl-log.html
On the other hand the Cosmos S is a beautiful case.
NCIX had a sale on the Cosmos S for $250 NCIX.com - Buy Coolermaster Cosmos S Black E-ATX Aluminum Case 7X5.25 4X3.5INT Front USB & Sound - RC-1100-KKN1 In Canada. which seems to be expired, but if you add it to cart, you still get that price with a note of c/o in 4 days.
edit: just read your post above.. I think the Tagan might be your kind of case.. If you look on overclock.net in the case mod work logs section, you should be able to find some logs on both cases which might help..
Old January 2, 2009, 04:42 PM
SugarJ's Avatar
I couldn't help myself. I picked up a Cosmos S today on the way home, NCIX Langley had some right out front.
I think the Black Pearl is still a killer case, but I'd have to do a bit of work to it, while the Cosmos is a bolt-on internal install. I might need a couple of new tubing runs, but that's it.
Worklog to follow. And a FS thread to get rid of my 900 and other spare parts.
Old January 3, 2009, 01:12 PM
So Sugar, how much you paid for it.. ? :P
Old January 3, 2009, 01:27 PM
SugarJ's Avatar
249 + tax. The wife wasn't too happy.
Off to pick up some of those red & black YL's now, and some fan grills.
Old January 3, 2009, 01:30 PM
If you want cheap grilles stop by the electronics shop across the street from ncix.
They have black ones or used to.
Old January 3, 2009, 01:38 PM
So you did get the same price on special, quite odd website says expired last year, oh well!!.. Great now get started on the worklog now, by whip is here..
Tagan Black Pearl vs TJ-09? Or go cheap CM590/690 Fracture Cases 29 November 20, 2008 12:28 PM
FS- Tagan Black Pearl (checking interest) mattlef Buy/Sell & Trade 18 October 7, 2008 07:24 PM
Tagan Black Pearl log lowfat Case Mods, Worklog & Gallery 83 August 31, 2008 11:46 PM
The Tagan Black Pearl :D mattlef Case Mods, Worklog & Gallery 6 August 30, 2008 09:07 AM
ASUS P5K3 Premium Black Pearl Edition (Intel P35) Prof. Dr. Silver CPU's and Motherboards 3 November 9, 2007 09:51 PM
