heeheh.
Welcome to the world of aerospace engineering my friend.
What you suggest is certainly possible , but you need to throw out your current idea's about running DI.Here's what I mean :
-'antifreeze' aka ethylene/propylene glycol can't handle Dry Ice , It'll freeze solid.
-Thing's like standard waterblocks and rads will contain several different metals soldered/welded/fitted together.The
thermal contraction that happens during a 100 degree temp shift can totally destroy these seals.
-Pumps for watercooling just won't work.they will fail forsure.Same reasons....
I have a worklog here about my attempt at DI cooling.mebbie you've seen it.
I tend to agree with Eldonko.You still have a lot of experiments with watercooling to do.Especially if it's only benching runs you wanna do.
I assume you know what 'open loop' watercooling is ? ( cold water tap into blocks , output to drain.)....Start there .Then try some peltier coolers.I've achived loaded temps of -21c with this method(load side).
Start there.Then you can try pre-cooling an open loop system with normal ice and salt.
If yah just wanna giver , I can certainly understand.
You need to look into building a lot of your own components , and spending cash.
Think 'alcohol loop'....custom pump.
