Old December 23, 2008, 08:49 AM
Soultribunal's Avatar
If you are going to use Dry Ice, then combine that with Isopropyl Alcohol for the best results.
I can't find my stats for the Thermal Properties of that particular substance, but its freezing Point is -89 degrees. That leaves you with a difference of -11 degrees in your favour with Dry Ice.
Isopropyl is not know to react with common Materials (no specifics in my manual on the substance). However I would take a section of the Tubing you intend to use, and a sample of material and test it with that to ensure no reactivity before attempting the loop.
Good Luck!
ST
www.realhardwarereviews.com
Old December 23, 2008, 02:26 PM
MpG's Avatar
MpG MpG is offline
Acrylic and any seals are definite danger zones with Iso. So yes, definitely test first.
Old December 24, 2008, 09:28 AM
BrainEater's Avatar
Yea Isopropanol will react with lots of things.Specific material compatibility basically needs to be done for each and every component....Also , with the low temps involved , you've got to do physical compatibility checks as well.
Isopropyl alcohol - Wikipedia, the free encyclopedia
eFunda: O-Ring Materials Compatibile with Chemical Isopropanol
The 'thermal property' that's of intest here is the viscosity curve of Isopropanol , but it's something you need to calculate rather than being able to just 'look up'.... I'll save yah the trouble tho ...
The viscosity of isopropanol varies from about 2 cP at 25 c , to ~300 cP @ -78 c.
The volumetric change that would occur at the blocks would be an issue too....the output barbs would need to be larger than the input one/s.....
If you are really serious , the first thing you need is a pump that can tolerate Iso and cold....I've already done this research too...
You want a fully stainless steel pump (shaft/impeller/housing), with silicone seals.You can expect to pay a few hundred dollars for this probably.
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
Old December 27, 2008, 08:27 AM
KaptCrunch's Avatar
if wanting constant chill best use a phase change set-up for direct die chilling
Caution:Methanol It forms explosive mixtures with air and burns with a nonluminous flame. It is a violent poison; drinking mixtures containing methanol has caused many cases of blindness or death. Methanol has a settled odor. Methanol is a potent nerve poison.
METHYL ALCOHOL freeze point -97.7 0C must use alcohol appoved tubing
also highly FLAMMABLE
Thermaltake Unveils Bigwater 770 Liquid Cooling System MAC Press Releases & Tech News 0 July 7, 2008 06:12 PM
Looking for a M-ATX case with liquid cooling and mod-ability Nate_The_Great Cases 4 March 6, 2008 04:12 AM
WTB: Liquid cooling system for CPU pat767 Buy/Sell & Trade 3 January 30, 2008 10:03 PM
Fear of Liquid Cooling Beermaster Water Cooling 29 June 4, 2007 11:14 AM
Ultra Liquid Cooling P4 1.7GHz to 5.2GHz BALISTX Water Cooling 2 March 12, 2007 06:16 PM
