Hi,
Some of you may know my hardware, but anyway :
I use a MM case, the ufo-horizon to be precise. Picture in the bottom.
I am watercooling the
-CPU (I7 920)
-GPU (GTX280)
all of this heat goes to the front mounted PA 120.3 with 6 push-pull 120 MM fans. The temperature are ok. Never go over 70 C for the fully loaded CPU while the GPU is a 36 C. So I am happy.
But then, Vortex decided to change this :
Few WC goodies
He is selling a PA 120.3 with 6 X 38MM ultra Kaze (this rad with fan + shroud is 8 inches wide !!!!!) and the shroud at a good price. Really long story short I bought it for a second build, who knows !
THE crazyness watercooling bug got me again.
Why not do a single loop with 2 pumps since it can all fit in my MM case ? LOL, that could be fun and huge overkill. Not 2 loops, since it is less fun (
), just one big dual RAD loop
..... So take a couple of second to think about it, what should be the loop ?
I had this idea :
CPU (GTZ) - DTEK GFX sur GTX 280 - PA120.3 (4 Yate loon 120 MM + 2 Shcyte) - MCP 355 (Petra top) - Swiftech RES V2 - PA120.3 (6 Ultra KAZE) with shroud - MCP 350 (petra's top) - back to the CPU
But then our newest moderator, charlie, showed me this cool link :
Ek Water Blocks EK-DDC Dual Turbo Top Custom Pump Top for 2X DDC or MCP350 or MCP355 Pumps G1/4 - DirectCanada
LOL, I will be already ordering some 1/2 inch tubing, so why not ?
Now anybody knows if 2 pumps in a single loop or 2 pumps with the EK block is better ?
Also, for thoses who had experience with the MM UFO-horizon :
You think I could screw the PA 120.3 with the 38 MM fans and the shroud on the 2 back case fan hole ? (the 3rd one is for a second PSU)
This should be fun. I think I'll get some pics for you of the current setup...
