Old December 9, 2008, 07:58 AM
Soultribunal's Avatar
Default Swiftech H20-120
Okay, so I am happy to say I will be steering clear of TT for their watercooling solutions!
Now, I would like some advice if possible on this Unit, if anyone has ever used it before.
The Case it would be going into is my NZXT Apollo. I should be able to do an Interal mount on this , I won't be pushing the Processor much past 3.33 (E8400) so I think the single rad would do the trick. I don't want to have to mount this outside the case using the RadBox, because where my computer is, it would put the Rad right up to the Cold Air Return in my house.
How expandable is this unit as well, because I had a cool thought of adding a Second Rad to the loop via mounting it on my Side fan Panel and making the fan Push instead of pull.
Just thoughts for now. Its a Cramped interior (much like all Mid-Towers) and to top it off my damn PS needs to be switched for a Modular as well, way to many cables floating around.
Thanks for your time everyone,
ST
www.realhardwarereviews.com
Old December 9, 2008, 08:43 AM
sswilson's Avatar
When I checked out the single rad H2O kit it didn't put out any better performance than a good air cooler. The 220 is where you start to see some WC benefits.
Old December 9, 2008, 09:22 AM
Fair enough, so putting a second rad onto the loop would work out in my benefit then?
Now I just need to find a place to buy them, and some accessories for them.
Thanks Wilson, appriciate your comment.
ST
Old December 9, 2008, 09:41 AM
Sniper's Avatar
Dual rad kit here NCIX Is a good place to start if you're in Canada. I didn't take notice to where you are sorry. It is easily upgraded as well.
Old December 9, 2008, 10:38 AM
Thats my mistake, was eager to join the Forums, not so much to fill out all my stats.
I'm from Canada so NCIX is available with me no problem.
I'll take a look Sniper, thanks!
ST
Old December 12, 2008, 06:10 PM
Varroa's Avatar
I used the H20-120 compact to cool my CPU and I got better performance using air cooling. I upgraded the rad to a Thermochill 120.1 rad and now I get decent cooling.
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
WTB:Swiftech H20-220 Compact Ken_C Buy/Sell & Trade 3 November 4, 2008 08:59 PM
Swiftech radbox Dr_BenD_over Water Cooling 5 October 28, 2008 06:16 AM
Swiftech Rad fine? frosty Water Cooling 11 October 25, 2008 01:13 PM
WTB: Swiftech MCP655 miggs78 Buy/Sell & Trade 0 October 7, 2008 02:39 PM
Help with Swiftech H20-120 kit Varroa Water Cooling 19 January 4, 2008 09:43 AM
