Old November 26, 2008, 08:32 PM
MpG's Avatar
MpG MpG is offline
The potential between the two metals is correct, but as best I understand it, Silver is considered a noble metal, and somehow resists corrosion altogether. Ditto for Gold. I have yet to find an explanation that offers more details, but that's my understanding. There has to be something happening, because Silver and gold are even further from Aluminum than copper is, yet the former are used to prevent corrosion.
Old November 26, 2008, 09:25 PM
biff's Avatar
Cant' seem to find it again but IIRC the chart showed gold as the most noble with silver close behind. Farther down the list was copper. As I understand it the more noble metals will not corrode where as the less noble metal will, i.e the silver won't corrode and the copper will in this case. I wonder though if the difference is small enough not to make a whole lot of difference.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old November 26, 2008, 09:39 PM
3.0charlie's Avatar
Galvanic corrosion - Wikipedia, the free encyclopedia
Table: Galvanic series - Wikipedia, the free encyclopedia
Hydro-Quebec is salivating...
Old November 26, 2008, 09:50 PM
MpG's Avatar
MpG MpG is offline
Even setting aside the idea that silver is supposed to 'resist' corrosion, I'm betting that the voltage difference is too small to become a meaningful issue. Those galvanization charts are usually put together based on salt-water electrolyte, which hopefully no one is using for coolant in their computer. Distilled water would be far less conductive.
Old November 26, 2008, 11:06 PM
joeperson's Avatar
From the wiki...
The following is the galvanic series for stagnant (that is, low oxygen content) seawater. The order may change in different environments
...so mpg has a point about the dissimilarity of the fluids in question. That doesn't say whether there's a problem or not in stagnant strange ass liquid cooling fluids though.
I wonder if small particles of silver can react on their own with the copper? The two major pieces may be separated but the whole point of the silver is to mix with the water.
What fluid did you use to fill your loop? (looking at the additives if any)
Q6600 3.0GHZ (9x333) stockV | ATI 5850 | OCZ Platinum 4GB PC2-6400 DDR2 5.4.4.15 1.9V | Silverstone Raven RV01 | Gigabyte EP45-DS3R
Corsair Professional HX750W | Windows 7 | Crossbow mounted Xigmatek HDT-S1283 | LG W2242TQ-BF 22" | Samsung 2253BW 22"
Old November 26, 2008, 11:11 PM
biff's Avatar
Awesome, a lasagna battery! Someones gotta try that!
That's one of the tables I was looking at. According to the chart BIG gap but I wonder how much of an influence it will have in real life, as MPG mentions the liquid will be distilled and not an electrolyte bridge. If I had to guess the same reaction will happen just MUCH slower.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old November 26, 2008, 11:48 PM
Apollo4g's Avatar
Originally Posted by biff View Post
I don't remember a whole lot of chemistry but a little googling shows that the silver and copper in the loop will form about a 0.2V cell with the copper (water blocks) being corroded. Can anyone confirm this true or false?
Hmmm i doubt it as Silver has an electron affinity of -125.7 and copper -118.3 the charge if any is very slight and negligible.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old November 27, 2008, 02:56 AM
Chilly's Avatar
I've been running a Pure Silver Storm G5 on nothing but pure distilled water for as long as I remember, no issues. I don't know the reasons why, but people on XS, etc with huge engineering degrees have explained time and time again that silver WILL corrode copper, but because of numerous factors it would take centuries running untouched before you could even BEGIN to notice anything.
Its got something to do with about silver being an inactive/inert metal, I believe which makes there distance on the galvanic scale irreleavent. I believe gold is the same way actually. What little I remember is that only way you'll get corrostion/damage in distilled water is if the silver and copper are directly touching each other. Otherwise nothing will happen with even a 1mm of distance.
  #19 (permalink)
Old November 27, 2008, 07:54 AM
Apollo4g's Avatar
Good to know!
Nice where did you get that G5?
  #20 (permalink)
Old November 27, 2008, 08:29 AM
Chilly's Avatar
Originally Posted by Apollo4g View Post
Good to know!
Caught it being sold used on another forum back in dec 2006, I jumped on it like white on rice. I almost bought a 2nd one but the guy who was selling it refused to sell it to me, he thought that since I was Canadian that our money was no good . If I ever come across another one,I will buy it in an instant, they are an excellent little piece of water cooling history.
Tags
biocide , silver , water cooling
