Originally Posted by odis172 Well todays graphics cards are bottlenecked by the cpu, so a good overclock can do alot. What are your system specs? In terms of cost your looking at least 100, not much more then that if you pick up some used parts. |
The difference between 3ghz and 4ghz in processing vs gpu is so minimal that you maybe gain perhaps 5-10fps in games.
Originally Posted by muse108dc Well it will be an i7 920 most probrably (unless Deneb is completely epic) and I do quite enjoy a nice overclock, current one is probrably pushing it a little on air. If it keeps the temps down significantly over air and extends the life of the processor due to those lower temps. Probably money will make me go air again but I just want to see how much it would take and what I would need. |
Until overclocking actually proves to be beneficial with the new i7 chips theres no real need yet to water cool them.
