Old November 19, 2008, 11:23 PM
S_G's Avatar
S_G S_G is offline
Yup, found some at Walmart's pharmacy department; they only had one kind though. Also picked up some black heater hose from Canadian Tire (who needs fancy clear tubing? ). Cleaned up my rad and stuff earlier today. Now all I'm waiting on is the CPU blocks. Thanks for the help, guys.
HTPC: MSI Z77A-G43 + [email protected] + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
