Old November 15, 2008, 04:04 AM
Jackquelegs's Avatar
Default Advice needed on WC
Hey guys, I'm planning out my new WC setup.
PA 120.3 + Swiftech MCR320 (with Ultra kazes and Panaflos, sorry I got those rads cheap, couldn't resist)
DD CPX-Pro Pump
Primochill 1/2 ID 3/4 OD tubing 20 feet
D-TEK Fuzion V1
Swiftech MCW60
Swiftech MCW30 (maybe, still deciding)
Swiftech Micro-Res V1
Coolermaster CM690
It's going to be cooling an overclocked Q6600, and 4870. Possibly a northbridge.
I would like some opinions on:
1. If the pump is powerful enough
2. If should I move onto a bigger case like a HAF 932
I appreciate any input. Thanks!
Iapetos
Zephyranthes
Old November 15, 2008, 04:29 AM
Sniper's Avatar
You could do one loop but 2 with 2 pumps would be much better imo. It's abit over kill with a triple rad on each but it'll keep it nice & cool. You won't need Ultra Kazes for either of those rads as they both are easy flowing. med fans at the most for either rad.
Old November 15, 2008, 08:12 AM
Babrbarossa's Avatar
I would just use the pa120.3 and skip the other rad- especially if you're tying to squeeze them in that cm 690
psst, wanna see my binder?
Old November 15, 2008, 09:33 AM
"Quote This..."
Skip the mcw30. its a tiny block that is restrictive and there is no where to put it anyways on your heat pipe mobo. I have one and don't use it. I tried it on the southbridge thinking the heat pipe would cool the rest but it made no difference in northbridge temps.
Old November 15, 2008, 10:18 AM
magictorch's Avatar
I'd be really careful using a core only block on the GPU as the 4870 gets pretty hot around the VRM's and the memory. If you do you'll, need good airflow over high quality heatsinks. For the VRMS I think the enzotech copper Mosfets will probably work quiet well although there are some other good other options out there. Personally I'd go full cover.
As for your loop I'm not sure you need two radiators yet for the cpu, nothbridge and GPU core. As Babs said use the PA120.3 mounted to the back with a radbox and some good fans. If you were using one or two gpus with a full cover block and NB block then another loop just for the quad cpu would be a good idea.
Old November 15, 2008, 10:32 AM
Supergrover's Avatar
+1
I have the mcw30 installed and it's not a very good block IMO, drops my NB 10c
right now idle my cpu is at 15c my NB is at 33c
Personally if you are dead set to watercool the NB there is waaaay better NB blocks out there.
I would do as Babs said drop the mcr320 and mount the 120.3 off the back.
R.I.P.
Old November 15, 2008, 12:50 PM
Thanks for input so far guys! Awesome.
I doubt I'm going to spend the worth of another MCW30 on MOSFET coolers for the mobo. So NB cooling is out of the way.
I do have an accelero V1 lying around, and the ramsinks and vrmsinks are included. Just need my thermal tape.
In terms of mounting..I might be moving on to a HAF 932, and I might also pick up another CPX-pro pump
Iapetos
Zephyranthes
Old November 15, 2008, 03:39 PM
biff's Avatar
The mcw30 ins't that bad... depending on what you need it for. I use one just so I don't have to run a fan on my NB and it's perfect for that since it has very low restriction. Also how are you getting your temps? on board sensors? If so there will always be some difference between the block temp and the onboard or on die temp sensors no matter how good the cooling solution - not including active coolers. That 15°C CPU is pretty nice though... water chiller?
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old November 17, 2008, 03:34 AM
Well just an update on the situation, I cancelled the order for a PA 120.3, and will be picking up a Feser Xchanger 360 from TerenceJ. Also from him I will pick up a Fuzion V2.
It's going to get a bit more restrictive with the fuzion V2, and I'm seriously thinking of either purchasing another pump for dual loop, or save the cash and go for single loop (probably wouldn't make much of a difference)
I also got the go-ahead for a new case next month..likely to be the HAF 932, but still needs to be decided
Iapetos
Zephyranthes
Old November 19, 2008, 07:16 PM
zlojack's Avatar
I've got a full set of brand new motherboard blocks for that board available if you're interested. I can't use them now that I'm going to i7
[SIZE=3]
