I am so tempted to ditch the HAF 932 and build on the CM690.
Now if I figure out a away around this problem, I will probably do.
How would I go to plumb for dual external mounts in a CM690? There are only 2 tubing holes available, and I need 4 since I have 2 loops.
I don't have a dremel at the moment.
