Old November 19, 2008, 08:18 PM
Jackquelegs's Avatar
Thanks for the offer, however I gave up on chipset cooling since FSB won't be pushed to extreme limits. I will have some AC modded on there.
Iapetos
Zephyranthes
zlojack's Avatar
No worries.
I almost hate to sell these blocks, they're so nice
But they don't fit and I doubt the X58 NB needs cooling.
Old November 19, 2008, 08:20 PM
They are really nice. I was planning on buying one before I gave up on the idea.
There's nothing worse than waiting for WC, since I got all my components ready to go. Except I don't want to do it in the CM690. So I'm waiting until xmas for the project.
Iapetos
Zephyranthes
Old November 19, 2008, 08:21 PM
zlojack's Avatar
I know the feeling!
I still have a way to go until I can get my whole rig together!
Good luck with your build. Watercooling is fun and addictive!
Old November 19, 2008, 08:31 PM
hey, looking forward to seeing the components in action! you betta post some pics after
MpG's Avatar
MpG MpG is offline
Asus has a halfway consistent track record of using consistent cooler mounting holes for their chipset/mosfets. I'm a little curious as to whether existing blocks might actually fit the X58 boards...
Old November 19, 2008, 08:33 PM
Hopefully X58 will use similar mounting holes.
TerenceJ: It's a dual loop WC. That'll keep you tempted
Iapetos
Zephyranthes
Old November 19, 2008, 08:57 PM
zlojack's Avatar
I spent a lot of time looking at pics of the P6T Deluxe.
I think the mosfets and SB block that I have currently would fit, but I think the NB holes are different.
I'm still not convinced that the X58 NB needs more than a little fan.
  #19 (permalink)
Old November 19, 2008, 09:03 PM
SugarJ's Avatar
Zlojack, seeing as the SB is an ICH10R same as the X38/X48/P45, the SB block should fit no problem.
  #20 (permalink)
Old November 19, 2008, 09:06 PM
zlojack's Avatar
The X38 and X48 use the ICH9R, only the P45 use the ICH10R, but that shouldn't make much of a difference.
It's just a chip. It still depends on how the MB manufacturer chooses the board layout.
That said, I don't think Asus has changed their SB layout for the P6T and so the block should fit, but I've got no confirmation for that.
