Old November 13, 2008, 11:23 AM
Default New to water - need advice!
hey guys, new to this forum!!
i was planning to w/c my sig rig within the next month or so and was looking for any advice or recommendations on components, loop order, etc.
W/C Parts:
Thermochill Pa 120.2 Dual 120MM Fan Water Cooling Radiator x2
Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
Swiftech APOGEE GTZ LGA775 CPU Water Block G1/4 Chrome HI-FLOW 1/2IN Barb Fittings
Danger Den Single Bay Reservoir 5.25IN 1/2IN Barbs
Feser One Feser Tube Clear UV 1/2IN ID 3/4IN OD Tubing (10 Feet)
Pts Petra PT_NUKE Concentrated Biocide Water Additive for Water Cooling (10ML)
Danger Den DD-4870-X2 Full Cover X-FIRE Ready Video Card Water Block for Radeon 4870 X2 1/2IN Barbs
Primochill Zinc Plated Steel Worm Drive Hose Clamps for 3/4IN OD Tubing
Feser One Feser View Red UV Reactive Dye Water Additive 50ML Bottle
Loop order:
Res -> Pump -> Rad1 -> CPU -> GPU -> Rad2 -> Res
Going to be putting this into a MM h2go. Planning to mount 1 rad internally on the intake and one on the back.
Is this enough to cool both the qx9650 and 4870x2?? Also is the pump good enough for this loop?
Thanks in Advance!!
Qx9650 @ 4.00ghz | Asus Maximus Formula x38 w/ Rampage Bios |2x2GB OCZ Reapers
ATI HD4870x2 | WD RaptorX 150gb + 3*500GB + 1000gb | PCP&C 750W Silencer
X-Fi XtremeGamer Fatal1ty | Logitech Z-5500 | HD555
Old November 13, 2008, 11:35 AM
Xilikon's Avatar
It works but I suggest 2 loops, 1 for the cpu and 1 for the 4870x2 then you will have optimal temps. You need just a extra pump and reservoir to get this.
Xilikon - Team 33
Proud to be [H]ard !
Old November 13, 2008, 11:49 AM
i considered doing 2 loops instead of one but i dont think i can fit that much into my case. :(
Old November 13, 2008, 12:50 PM
Cptn Vortex's Avatar
Plenty of space....
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old November 13, 2008, 01:23 PM
MpG's Avatar
MpG MpG is offline
If you're using the Thermochill rads, be aware that they use a different fitting size, and don't come with the fittings. You'll want G3/8 fittings in this case, two for each rad. Personally, I recommend THESE guys, as they're very well designed and user-friendly.
Also, hose clamps are hose clamps. You can just as easily grab a handful from your local hardware/automotive store, possibly for less. No need to pay a premium for the Feser ones.
Old November 13, 2008, 01:56 PM
zlojack's Avatar
You can fit two loops in that case.
Either using T-lines or a dual chambered single-drivebay res.
I'm going to be building one with 3 loops soon (if I can ever get all the gear together )
You might want to think about smaller tubing
I'm using 3/8"-1/2"
But you could also go 3/8"-5/8"
It will help.
Old November 13, 2008, 03:40 PM
sswilson's Avatar
Have you done much research on your choice of res? I've never used a 5 1/4 bay res myself, but I know some folks are dead set against them.... might be worth your while to do some digging to see if you can find out why.
Old November 13, 2008, 03:43 PM
zlojack's Avatar
5 1/4 bay reservoirs are great.
Some people won't use acrylic. Also, the ones that are front filled can be hard to use.
You might want to think about the MCP355. The smaller footprint will help as things get tight down below in the H2GO
Then you could check out the reservoir top from XSPC for that pump. I think it will fit in the bottom of that case. (Maybe not. I'd measure it.)
Old November 13, 2008, 03:46 PM
MpG's Avatar
MpG MpG is offline
Some 5 1/4" res' are useless, that's why. No baffles, improper inlet/outlet positioning, poor acrylic sealing, prone to leaking... they have a colourful history, unfortunately. A few years ago, I know the DD reservoirs were a little spotty, but I haven't heard anything either way more recently. They're usually pretty good at fixing problems, so I can't imagine the problem's stuck around this long.
Old November 13, 2008, 03:49 PM
Chilly's Avatar
I agree on the dual loop suggestions here, you'll have plenty of space in that case. Other than that your part choices are good, I have no arguments with the parts you've chosen. (not that it should matter what I think ) I do have a few suggestions for your loop/loops thou
If you do dual loops
Loop 1
Res -> Rad1 -> Pump -> CPU -> -> Res
Loop 2
Res -> Rad2 -> Pump -> GPU -> Res
If you do single loop
Res -> Rad1 -> Rad2 -> Pump -> CPU -> GPU -> Res
Modify as much as you need in order to obtain least amount of tubing/ease of fit in case. Just follow these few basic rules, never connect the pump outlet to a rad or res, if you do, your throwing away turbulence creating head (remember, head is good, you never wanna lose head, direct the head toward your blocks which can benefit from it). 2nd, make the loop as simple as you can(ie use the least amount of tubing possible). Follow those 2 rules when putting together a loop and you'll have a great performing loop!
