Old November 13, 2008, 03:57 PM
zlojack's Avatar
I was under the impression that connecting the pump to the rad first was a good thing, because it would thus be delivering the coolest water to the blocks.
Old November 13, 2008, 04:00 PM
Xilikon's Avatar
Correct, the best way is RES -> PUMP -> RAD -> BLOCKS
Xilikon - Team 33
Proud to be [H]ard !
Old November 13, 2008, 04:13 PM
MpG's Avatar
MpG MpG is offline
Head is head is head. All else being equal, I've never seen evidence to suggest that the order of components affects the pressure drop across each one, and it's the pressure drop, not the absolute pressure that allows the turbulence to happen. That said, the temperature difference between the fluid going in and out of a block is pretty minimal too, as long as you're maintaining good flow rates. So if putting the rad elsewhere in the loop makes things a lot simpler, I wouldn't sweat it too much.
Old November 13, 2008, 04:55 PM
Chilly's Avatar
Personal experience says otherwise, just do me a favour, and don't EVER hook the pumps outlet to the res. You lose all head pressure that way
I'll bend on this one, as long as your not doing something stupid such as connecting the output of the pump to a res(therefore losing effectively ALL the head), you *shouldn't* lose enough pressure to matter(with in a few C's anyways). ALWAYS go for the least amount of tubing/easy of routing possible.
Like I said personal experience says otherwise but that may have something to do with the fact that I'm rocking on a Cather Storm G5, which is a very head hungry block.
Old November 13, 2008, 04:57 PM
zlojack's Avatar
Well, obviously never hook the pump outlet to the Res!!
But hooking it to the rad should be ok.
Old November 13, 2008, 05:17 PM
Xilikon's Avatar
I never said to hook it to the outlet... However, always put a reservoir to feed the pump INLET or it will get starved and risk damaging the pump.
Xilikon - Team 33
Old November 13, 2008, 05:34 PM
Chilly's Avatar
You also never said anything about a res, I was agreeing with your points silly .
That said, yes, you wanna ensure a pump is always filled with water when you turn it on, otherwise you risk damaging the pump very easily.
