Old November 8, 2008, 07:26 AM
Supergrover's Avatar
Default Soups loop questions thread.
Okay I have had quite a few questions about my loop lately so I thought maybe 1 thread would be better than a bunch of different threads.
So todays question is what is better res>pump>blocks>rad
or
res>pump>rad>blocks.
Blocks are cpu/NB/gpu, not full coverage.
I know the pump will dump some heat into the loop but would it be enough to be concerned about?
R.I.P.
Old November 8, 2008, 07:38 AM
sswilson's Avatar
Everything I've seen suggests that it makes little difference. I'd go with whatever works best for installation of the loop.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old November 8, 2008, 07:46 AM
While I have you here then Steve, compression fittings: hand tighten them? Or give them a slight turn with a pair of pipe wrench? What about a slight dab of locktight? Fittings are fester 45 deg compression and bitspower compression. Both have the short threads.
R.I.P.
Old November 8, 2008, 07:52 AM
sswilson's Avatar
If the fittings work anything like the older thermaltake ones (only really good part about a thermaltake WC loop... :) ), hand tightening is more than sufficient. (Are you asking about tightening the threads, or tightening the hose?).
As far as the short threads go..... I've only had to use thread sealer on one type of fitting, and wouldn't bother unless I found that I needed it after leak testing. What are the o-rings on those like? If there's not a lot of meat to them, you might want to pick up some thicker ones at the local hardware store. That might help getting a better seal, and prevent a lot of headaches during the leaktest phase of the build.
Old November 8, 2008, 08:10 AM
I am talking about the threads into the block, with a standard fitting I hand snug then 1/4-1/2 turn. I think the tube side will get a slight pipe wrench to it.
The short threads concern me a little since they are so short and the festers are swivel fittings and I thought they might work loose over time if just hand tightened.
R.I.P.
Old November 8, 2008, 08:13 AM
sswilson's Avatar
Ok, I thought you were talking about the tube side. I'd give the threads a slight crank (1/8 - 1/4 turn) with a pipe wrench, but you probably don't need to do more than hand tighten the hose side.
Old November 8, 2008, 08:14 AM
Ahh I had it ass backwards then.
R.I.P.
