Old November 7, 2008, 08:59 PM
Supergrover's Avatar
Default Enzotech Luna
Since I cant find much info review wise does anyone have a link to a review or results thread?
The LED will not be plugged in and the lack of any bowing has me concerned plus there has to be a deceit pressure drop with all them pins.
Thoughts? Links?
EnzoTech
R.I.P.
Old November 7, 2008, 11:27 PM
JD JD is offline
If you aren't going to use the LED, why bother? That block is all about the bling...
My feeling is if it's not popular on XS, it probably isn't that great of a block. It doesn't even have it's own thread which is really sad IMO.
Old November 8, 2008, 12:12 AM
Cptn Vortex's Avatar
Very pretty though. I like the look of it.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old November 8, 2008, 06:59 AM
Actually there is a thread at XS, unfortunatly it is a pretty new WB and there isnt any results there yet.
I dont see the point in hooking up a led in a case that is all UV lights except the front 2x120mm blue leds but I have the sides blacked out so that the light doesnt spill back into the case. They are attached to my rad up front..
R.I.P.
Old November 8, 2008, 06:10 PM
JD JD is offline
Oh, I searched "enzotech luna" on XS and nothing came up...
Well any reason why you seem set on the Luna? There's a bunch of other good blocks out there that have lots of information about them.
Old November 8, 2008, 06:42 PM
Oh I am not set on it at all I just wanted some more info since I cant seam to find any.
I want to use compression fittings bitspower preferably or festers and since they don't fit every waterblock. I don't think they will fit the BP but the fester are 45* so they might have the clearance.
Heres the top result from my search on XS
Enzotech-LUNA CPU waterblock - XtremeSystems Forums
R.I.P.
Old November 8, 2008, 06:45 PM
MpG's Avatar
MpG MpG is offline
THIS is the XS thread on it, I couldn't find it with their search function either.
Can't quite warm up to the style myself, but it's got the general ingredients for a solid block. Micropin architecture, center-impingement design - it may turn out mediocre, but I honestly can't believe this block would actually wind up sucking. And remember, even between the venerable Apogee GT and the latest blocks, there's only a few degrees difference. Without a bow in the block, there may be some gains to be had by lapping the processor, though. Could be a bit of a flow-killer, but that'll depend on whether there's any clearance between the midplate and the base pins.
Old November 8, 2008, 07:25 PM
JD JD is offline
The OCZ HydroFlow would be another option then.
No offense but why do you say "fester"? It's Feser.
Old November 12, 2008, 06:57 AM
Sorry JD had sometime off and the wife wouldn't let me on the computer,
Yeah I know it is feser, fester is just my mental name for there products, mushkin=munchkin. Seams I typed it a few times like that now
Anyways back on topic: the Luna is out for me, 1/2id 3/4 od compression fittings wont fit but I am going to give that OCZ a try.
It isn't a top performing block as say the fuzion or supreme more on par with the GT but by god it fits bitspower's fittings
Oh the reason it didn't show in a search at XS I think was because I search from within the sub-forums, when I did a search via the frontpage it didn't come up with anything either.
R.I.P.
